    Motor fase error while homing
    • johny
      johny last edited by
      Hello (again :S)
      One more step 1 more question:s
      I am done with the vibration and temp problems but now while homing i get the following warning:
      warning
      Gcode:
      M92 X100.00 Y100.00 Z400.00 E100.00 ; set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-33 Y-10 Z0 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      M574 X1 Y1 S0 ; set active low and disabled endstops
      M574 Z1 S2 ; set endstops controlled by probe
      johny 1 Reply Last reply Reply Quote 0
      • johny
        johny @johny last edited by
        note:
        Board: Duet WiFi 1.02 or later
        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
        Duet WiFi Server Version: 1.23
        • johny
          I just figured out that the homex macro was lifting the Z-axis that was disconnected, i am sorry :S
          dc42 1 Reply Last reply Reply Quote 1
            dc42 administrators @johny last edited by
            @johny, I'm glad you solved it!
