    Duet 3 6HC does not Ping
    744
    • Philippe71undefined
      Philippe71
      Impossible to connect to a duet3 6HC by RJ45, the board doesn't ping.
      My configuration :
      Duet3 6HC + RRF3.0
      I try to connect to the 6HC card by RJ45 cable, the card doesn't ping.
      On the SD card I have the same directories from another card that works :
      filaments
      gcodes
      macros
      sys
      www
      I've tried Static IP and DHCP, same result.
      I erased the firmware and reflashed the firmware with Bossa.
      When switching on, the red LED flashes every second and the RJ45 port LED remains off.
      I connected a Pi4 by SBC, same RJ45 cable, the 6HC card works fine and firmware is OK.
      Does anyone have an idea.
      Dougal1957undefined A Former User? 2 Replies Last reply Reply Quote 0
      • Dougal1957undefined
        Dougal1957 @Philippe71
        @Philippe71 your not by any chance using the same SD card as the PI one supplied are you?
        Philippe71undefined 1 Reply Last reply Reply Quote 0
          When you are running in standalone mode and you connect via USB, does M552 confirm that Ethernet is enabled and the board has an IP address?
            Philippe71 @Dougal1957
            @Dougal1957
            I use an other SDCard, a copy of card working on an other Duet3 6HC
              Philippe71 @Philippe71
              I am sorry, I don't know how to connect to the Duet 3 by USB...
              (I used USB only with Bossa to upload firmware)
              How can I connect ?
              On the SDcard, in sys/config.g I have the line : M552 S1 P0.0.0.0
              Do I have to add something ?
              • A Former User?
                A Former User @Philippe71
                @Philippe71 said in Duet 3 6HC does not Ping:
                Confused. Pi4 is the SBC. Connection between Pi4/SBC and Duet should be by ribbon cable and not RJ45.
                Please clarify if you are trying to run the board in stand alone mode. Post config.g file from SD on Duet3 6HC.
                If you are trying to run the board with the Pi4 and Duet Software Framework then you should have no SD card with /sys/config.g in Duet3 6HC, and the board will not respond to ping. Network connectivity provided by Pi4.
                • A Former User?
                  the duet3 should show up as a serial port, connect to it using your prefered terminal or follow the same instructions as for the duet2 range.
                    Philippe71 @A Former User
                    @bearer
                    Sorry for confusing, I try explain better :
                    I try to connect a Duet3 by RJ45 as standalone mode.
                    The board do not ping.
                    Just for checking it is not a problem in my network or in the firmware of the board, I connected a Pi4 with ribbon cable, the Pi4 connect to the duet and I have access to DWC by the network.
                    My config.g :
                    M550 P"duet3" ; set printer name
                    M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S1 ; enable FTP
                    M586 P2 S1 R23 ; enable Telnet
                    • A Former User?
                      Okay, what is the other end of the RJ45 cable connected to?
                      To connect by USB to provide dc42 with what he asked for please forllow step 2 through 6 here (it should be pretty much the same for the Duet 3 as for the Duet 2)
                      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s5
                        @bearer
                        I succesfully connected to the Board by USB (with Repetier host).
                        M552
                        Return
                        Ethernet is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                        I sent :
                        M552 P192.168.0.209/24 S1
                        Return :
                        Ethernet is enabled, configured IP address: 192.168.0.209, actual IP address: 192.168.0.209
                        and the board ping now
                        when I try to connect to DWC by network :
                        I downloaded and install in /www the version 2.07 of DWC
                        Same problem
                        To be sure it is not a problem in my config.g, I created on the SCCard a config.g with only this lines :
                        M552 P192.168.0.209/24 S1 ; enable network set static IP
                        No ping with this config.g file
                        Connecting by USB and sent M552
                        Sent command M552 P192.168.0.209/24 S1
                        Ethernet running, IP address = 192.168.0.209
                        Trying to connect to DWC by network:
                        I'll try one other SDCard...
                        • A Former User?
                          A Former User
                          If the problems persist, please run M39 from USB and post the output
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M39_Report_SD_card_information
                            @bearer
                            Tried one other SDCard, same problem...
                            M39
                            return
                            Error: No SD card mounted in slot 0 !!
                            How can I mount the SDCard ?
                            • A Former User?
                              Suspected as much, please verify the same error for the other SD card and then maybe @dc42 can chime in.
                              (edit @ dc42 does the Duet 3 handle sd cards with multiple partitions if the cards have been used for raspberry pi images as well?)
                                Philippe71
                                Just for info : Tried to reformat the SDCard with SDFormater (I guess only one partition) then copy all the files : same problem, a M39 give Error : No SD card mounted in slot 0
                                This board is a evaluation board bought beginning October 2019, maybe a problem with this board ?
                                • A Former User?
                                  i don't know if that tool "fixes" the partition table. sounds like you're in windows, so you can use disk management to see if there are more than one partition on the card. Hit windows key + X and choose Disk Management and have a look when the card is inserted in the computer ofc.
                                  (But yes, i suspect there could be a problem with the board, but that is for Duet3d to determine. It wouldn't be related to being an evaluation board, it would just be one of those things in electronics manufacturing ... however lets review the SD cards first)
                                    Philippe71
                                    The disk management show only one partition (main partition).
                                    Thanks for your help
                                      What size SD card is it, and how is it formatted? It must be formatted as FAT16 or FAT32 for the Duet. Cards larger than 32Gb have to be formatted as EXFAT and can't be used in the Duet, because EXFAT is patented.
                                      If you change the SD card in the Duet while it is powered, you need to either reset it or send M21 to re-mount the SD card.
                                      • A Former User?
                                        (just a general suggestion; next time post a screenshot to show us what you see. as shown by dc42s response, there are usually some details to be considered)
                                          Philippe71
                                          It is a 16Gb formatted in FAT32
                                            Philippe71
                                            Tried with 3 SDCard (16Gb)
                                            M21
                                            Error: Cannot initialise SD card 0: Card is unusable
                                            M20
                                            Begin file list
                                            NONE
                                            End file list
                                            Should I buy a new SDCard ?
