topic_solved Code 10 issue
I am trying to connect a new laptop to my Duet3D controller after the old one died, its been a few months since i last used it but i am having problems connecting with the USB.
I have installed the drivers but had to do so through device manager "Add legacy hardware" as it would not show up itself.
However the device will not connect and i am getting a (Code 10 error) I have tried two USBs and both USB ports on the laptop
The duet does light up when connected so i know it is at least getting power.
Anyone have any input or advice?
replace the driver with this one
https://github.com/dc42/RepRapFirmware/blob/dev/Driver/DuetDriverFiles.zip
Thats the file i used, i have re-installed the driver but with no change...
Still showing a code 10
@Jroliver said in Code 10 issue:
that should not be necessary and might cause problem
if you disconnect the duet usb is the driver still in the list?
Do you have a different PC to try with?
Do you have a powered USB hub to try with?
Have you used this laptop for this in the past? -
@Veti Yes, its still in the list, the computer was not detecting the controller before.
- Not at the moment, i am trying to get the old one running again.
- I do have a usb hub, but no change
- I have not used this laptop for any CNC work. though i use it for all my CAD work and have not had any issues with any other hardware.
that means nothing is detected. so just installing a driver will not work.
please remove the device and try a different usb cable as @phaedrux suggested. -
Ok, looks like it was a USB cable issue... I have found a forth cable and this one connects, the others must have been power only.
Thanks for getting back to me.
