    Fried driver Tmc2660
    1675
    • ProjectK
      ProjectK last edited by
      Nice, it seems like i fried my Z-Axis driver.
      Everything worked fine, and all of the sudden i saw a small spark and immediately plugged out the power supply.
      The motor current for Z was set to 1,5A, the Stepper I was using was a Nema17 2,5A,the Z was working fine the last days, i don't know what happened, but it was right after->
      https://www.duet3d.com/forum/thread.php?id=1460
      Did i messed everything or is there a warranty? I'm not sure if it was a good idea to build the Z-Axis like i did, pls help :3
      https://youtu.be/1rfaLsO55dg
      Creativity knows no borders!
      • elmoret
        elmoret last edited by
        I'm sure Tony or David will be along shortly to comment, but in the meantime you might be able to get going again by mapping Z to a different driver.
        http://reprap.org/wiki/G-code#M584:_Set_drive_mapping
        But you'll first want to check that there are no problems in your stepper motor wiring - pinched/shorted wires, intermittent connections, etc.
        • ProjectK
          Edit: I'm using 24V, also my heatbed shows
          -22°C.
          I just read in another thread that it could mean something with the VSSA fuse.
          Yes, I have Duex2, there is one free driver left, but first i want to be sure that i did nothing wrong 🙂
          It's 3:15 in Germany right now, I'll go to sleep, i't can wait till tomorrow/later the day
          Thanks!
            Where did you see the spark?
            Is the hot end temperature also reading -22C or thereabouts, or it is reading normally?
            • ProjectK
              I didn't see the spark directly, it was a small flash and a little plopping noise near the Z connections of the board, after I cut the power supply there was a smell of fried electronics
              The Hotend reads normal, actually my duet is completely unplugged
                If the hot end temperature is reading normally and it uses a thermistor for temperature measurement, then the VSSA fuse is ok.
                Please check that there is no possibility of a short in the Z motor wiring, and that the underside of the Duet isn't shorting against anything underneath it.
                • ProjectK
                  i checked everything, the hardware and the wiring was ok.
                  i guess the way my Z Axis is built and the fact that i used 1/256 steps for Z could be the reason why, im not sure
                  but the TMC2660 should handle 2,8A, and i'm sure there was no short or high-current drain
                    Ask your supplier to replace the Duet under warranty.
