    Heightmap lost adjustments of G32 ...
    3D Printing General Chat
    733
    • Tobs94undefined
      Tobs94
      homeall.g config.g bed.g
      using: RRF2
      36 points probed, mean error 0.368, deviation 0.251
      Height map saved to file heightmap.csv
      Leadscrew adjustments made: -0.019 0.095 -0.008, points used 3, deviation before 0.042 after 0.000
      Leadscrew adjustments made: -0.010 0.122 -0.181, points used 3, deviation before 0.087 after 0.000
      G32
      Leadscrew adjustments made: -0.062 -0.049 -0.676, points used 3, deviation before 0.338 after 0.000
      heightmap.csv
      this happens again and again. What im doing wrong ?
      Axis on Board (Duex5) 6/7/8 front left / rear mid / front right
      For me it looks that he just looses the G32 adjustment.
      Pls Help 🦌
      • Vetiundefined
        Veti
        can you just use the bed.g suggested in the article
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        your has 3 runs and G29 and G30 in them and changes to M671
        • Tobs94undefined
          Tobs94
          still the same issu
          • Vetiundefined
            Veti
            @Tobs94 said in Heightmap lost adjustments of G32 ...:
            G32
            did you copy that from the console? i.e is the first line the first or last message?
            • Tobs94undefined
              Tobs94
              15:36:01 G32
              Leadscrew adjustments made: -0.375 -0.031 -0.036, points used 3, deviation before 0.188 after 0.000
              15:35:25 G32
              Leadscrew adjustments made: -0.254 -0.115 -0.233, points used 3, deviation before 0.199 after 0.000
              doing this now in a row.
              why the printer is not adjust the bed ?
              • Tobs94undefined
                Tobs94
                heightmap.csv
                Vetiundefined 1 Reply Last reply Reply Quote 0
                • Vetiundefined
                  Veti @Tobs94
                  @Tobs94
                  please post the picture rather than the csv of the heightmap
                  • Tobs94undefined
                    Tobs94
                    • Tobs94undefined
                      Tobs94
                      @Veti
                      like this ?
                      • Vetiundefined
                        Veti
                        can you post your new bed.g? and which firmware version are you running?
                        • Tobs94undefined
                          Tobs94
                          bed (1).g
                          • Vetiundefined
                            Veti
                            please update to 2.05 and retry
                            • Tobs94undefined
                              Tobs94
                              1.2.2020, 16:11:06 G29
                              36 points probed, min error -0.125, max error 0.820, mean 0.377, deviation 0.242
                              1.2.2020, 16:09:29 G32
                              Leadscrew adjustments made: -0.313 -0.129 -0.144, points used 3, deviation before 0.202 after 0.000
                              1.2.2020, 16:08:51 G32
                              Leadscrew adjustments made: -0.179 -0.097 -0.158, points used 3, deviation before 0.143 after 0.000
                              1.2.2020, 16:08:12 G32
                              Leadscrew adjustments made: -0.231 -0.135 -0.178, points used 3, deviation before 0.180 after 0.000
                              • Vetiundefined
                                Veti @Tobs94
                                not that easy to see a trend but the deviation seems to be increasing, suggesting that your motor cabling does not correspond to the points defined.
                                You must use the M671 command to define the X and Y coordinates of the leadscrews. The M671 command must come after the M584 command and must specify the same number of X and Y coordinates as the number of motors assigned to the Z axis in the M584 command; and these coordinates must be in the same order as the driver numbers of the associated motors in the M584 command
                                • Tobs94undefined
                                  Tobs94
                                  @Veti
                                  i checked that for 100%
                                  was testing and swaped front left and rear mid and now the test really starts to get bigger differences
                                  Vetiundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                  • Vetiundefined
                                    Veti @Tobs94
                                    there are 6 different posibilities to adjust 3 wires.
                                      droftarts administrators @Tobs94
                                      @Tobs94 First, if you have not done so, update your firmware to RRF 2.05. https://github.com/dc42/RepRapFirmware/releases/tag/2.05
                                      Then, check your Z motors are connected to the correct drivers. From your config.g:
                                      M584 X0 Y1 Z6:7:8 E3                                   ; set drive mapping
                                      M671 X-15:173.5:362 Y118:374:118 S4                         ; leadscrews at rear left, front middle and rear right
                                      M208 X340 Y340 Z300 S0                             ; set axis maxima
                                      Gives:
                                      Does this look correct?
                                      • Tobs94undefined
                                        Tobs94
                                        Yes that is exactly how it looks like.
                                        @droftarts
                                        • Tobs94undefined
                                          Tobs94
                                          7.2.2020, 15:44:15 G32
                                          Leadscrew adjustments made: -0.141 -0.114 -0.166, points used 3, deviation before 0.133 after 0.000
                                          7.2.2020, 15:43:27 G32
                                          Leadscrew adjustments made: -0.138 -0.151 -0.140, points used 3, deviation before 0.144 after 0.000
                                          7.2.2020, 15:41:24 G32
                                          Leadscrew adjustments made: -0.069 -0.167 -0.206, points used 3, deviation before 0.141 after 0.000
                                          7.2.2020, 15:40:40 G32
                                          Leadscrew adjustments made: -0.133 -0.130 -0.066, points used 3, deviation before 0.122 after 0.000
                                          7.2.2020, 15:39:26 G32
                                          Leadscrew adjustments made: -0.349 0.038 -0.080, points used 3, deviation before 0.176 after 0.000
                                          7.2.2020, 15:38:36 G32
                                          Leadscrew adjustments made: -1.094 0.434 -0.084, points used 3, deviation before 0.524 after 0.000
                                          7.2.2020, 15:37:52 G32
                                          Leadscrew adjustments made: -2.909 2.198 -0.556, points used 3, deviation before 1.563 after 0.000
                                          still the same problem.. made me so mad. there must be 1 fault anywhere.
                                          bed.g homeall.g config.g
                                          (Next Problem my Fan is now always on and they did not get shown on Web Control after update)
                                          Thanks for help
                                          @Veti @droftarts
                                          tobias_munichundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                          • Tobs94undefined
                                            Tobs94
                                            and my Stall detection did not react anymore since update. No Change between -60 and +60
