    Heater can't keep temperature up
    324
    • id104335409undefined
      id104335409
      Hi, I am having trouble keeping the temps constant. As soon as they drop to .99 I get this :
      Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
      I did an auto PID tuning twice and saved it, but the heater just can't keep up and I don't know how to boost it up.
      Also while the test print job runs I have no control over my cooling fan. So I can't lower it to test if it is too high.
      Normally I can set it to run at whatever percentage I want, but not while it prints?
      Duet WiFI
      The printhead is a Titan Aero with just the cooling fan.
      This is my config:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Jan 30 2020 16:44:56 GMT+0200 (Eastern European Standard Time)
      M550 P"QB" ; set printer name
      M667 S1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z500.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z900.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X2000 Y2000 Z2000 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X500 Y500 Z500 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
      M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M140 H-1 ; Disable heated bed
      M501
      and the override config file
      ; config-override.g file generated in response to M500 at 2020-02-02 18:34
      ; Heater model parameters
      M307 H0 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H1 A662.8 C268.2 D8.4 S1.00 V12.0 B0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
        Phaedrux Moderator @id104335409
        @id104335409 said in Heater can't keep temperature up:
        Which cooling fan do you mean? The heatsink fan or the part cooling fan?
        The heatsink fan is configured to be controlled thermostatically based on the temp of the heater, so once above 45c it will be on full power.
        The part cooling fan should show up as a slider in DWC and should be controllable. It's a good idea to set the part cooling fan during the PID tuning to be at the same speed you would normally be using for an actual print.
          id104335409
          there is only one fan - the heatsink fan, but the problem is heating is not turning on and off in a way that keeps the head above the printing temperature and if it drops by 0.1 degree it just refuses to push filament so not to cause jams. the fan should be at 100% anyway, but I was surprised to see the slider didn't control it anymore.
            What temp are you trying to reach? What does the graph look like?
              id104335409
              100 degrees, graph is straight line. Dips are just down from 100 to 99.99.
              otherwise I can go up 225 I believe. Temperature is not an issue.
              jens55undefined 1 Reply Last reply Reply Quote 0
              • jens55undefined
                jens55 @id104335409
                @id104335409 , are you trying to extrude filament at 100C ???? That will not work as your temperature is too low.
                The ' tool not driven ' error message only shows up if you are trying to extrude.
                You are saying you can reach 225C and temperature is not an issu so why are you testing things at 100C ... try testing at 200C instead.
                  id104335409
                  Oh, Im so sorry - this is just a test run , no need for filament all over the place. I'm just adjusting the printer.
                  Heater, sensor, e steps, bed level and so on.
                  Is there a failsafe that doesn't allow extrusion under certain temperature?
                  • deckingmanundefined
                    deckingman @id104335409
                    @id104335409 Yes there is. But you can use M302 to allow cold extrusion.
