    topic_solved Duet3 0.6 firmware upgrade from RRF 3.0alpha
    Firmware installation
    83
    • oliof
      oliof last edited by oliof
      I am working on getting a printer up and running with my Duet3 0.6 board, and am looking to update the firmware
      My board:
      FIRMWARE_NAME: RepRapFirmware for Duet 3 v0.6
      FIRMWARE_VERSION: 3.0alpha
      ELECTRONICS: Duet 3 version v0.6 FIRMWARE_DATE: 2019-09-05b2
      I run the board in SBC mode with a Raspberry Pi 4, using the SD card that was provided with the board. The installatio
      The releases say Users of Duet 3 with attached Raspberry Pi should update from the Pi using sudo apt-get update followed by sudo apt-get upgrade, but that does not seem to work.
      Do I need to take special provisions coming from RRF 3.0alpha?
        I don't think you need to do anything special coming from 3.0alpha.
        • tobias_munich
          tobias_munich last edited by tobias_munich
          i assume with "...apt upgrade" we will get a set a set of stable releases for DSF,RRF,DWC "only".
          i don't know if the standard image of the RPI will upgrade to the DSF beta releases too.
          i don't think so.
          but...
          you have 3 types of software packages:
          1. DSF (Duet Software Framework on your Pi)
          2. RRF/DUET Firmware
          3. DWC (Duet WebControl)
          DSF will be upgraded only and always with "apt upgrade"
          RRF-Firmware and DWC should be installed over the web interface as usual because they will not be distributed with the "unstable" releases right now.
          PS: to get unstable releases of the DSF software you have to add these repositories
          wget -q https://pkg.duet3d.com/duet3d-unstable.list
          sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
          sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
          • oliof
            Trying to upload Duet3Firmware_MB6HC.bin from the 3.0 release
            I get the following trying to apply the update via DWC
            2/4/2020, 10:09:45 AM	Upload of Duet3Firmware_MB6HC.bin successful after 1s
            2/4/2020, 10:09:48 AM	Connection interrupted, attempting to reconnect...
            2/4/2020, 10:09:50 AM	M997 S0
            Error: Code has been cancelled
            2/4/2020, 10:09:51 AM	Connection established
            2/4/2020, 10:09:51 AM	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
            2/4/2020, 10:09:56 AM	Connection to Duet established
            2/4/2020, 10:09:56 AM	Warning: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C.
            (note M997 S0 Error: Code has been cancelled)
            Then the board resets and is still on 3.0 alpha.
            M122 output:
            M122
            RepRapFirmware for Duet 3 v0.6 version 3.0alpha running on Duet 3 version v0.6
            Board ID: 08DGM-9T66A-G63SJ-6J1D6-3SD6R-9U0BA
            Used output buffers: 1 of 32 (6 max)
            Static ram: 67772
            Dynamic ram: 156056 of which 0 recycled
            Exception stack ram used: 224
            Never used ram: 169164
            Tasks: NETWORK(ready,2044) HEAT(blocked,1236) CanReceiv(suspended,3804) CanSender(suspended,1496) CanClock(blocked,1464) TMC(blocked,592) MAIN(running,4216) IDLE(ready,156)
            Owned mutexes:
            Last reset 00:00:09 ago, cause: watchdog
            Last software reset at 2020-02-01 20:24, reason: Unknown, spinning module Platform, available RAM 168948 bytes (slot 1)
            Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
            Error status: 0
            Free file entries: 10
            SD card 0 detected, interface speed: 0.2MBytes/sec
            MCU temperature: min 28.8, current 29.5, max 29.6
            Supply voltage: min 24.0, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
            Driver 0: standstill, reads 19526, writes 14 timeouts 0, SG min/max 0/0
            Driver 1: standstill, reads 19527, writes 14 timeouts 0, SG min/max 0/0
            Driver 2: standstill, reads 19528, writes 14 timeouts 0, SG min/max 0/0
            Driver 3: standstill, reads 19529, writes 14 timeouts 0, SG min/max 0/0
            Driver 4: standstill, reads 19529, writes 14 timeouts 0, SG min/max 0/0
            Driver 5: standstill, reads 19531, writes 14 timeouts 0, SG min/max 0/0
            Date/time: 2020-02-04 10:10:00
            Slowest loop: 7.28ms; fastest: 0.31ms
            Hiccups: 0, FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
            === MainDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            http* is ready with "M122" in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon* is idle in state(s) 0
            queue is idle in state(s) 0
            lcd is idle in state(s) 0
            spi is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 0.54ms; fastest: 0.01ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
            HTTP sessions: 0 of 8
            - Ethernet -
            State: 0
            === Linux interface ===
            State: 0, failed transfers: 1
            Last transfer: 86ms ago
            RX/TX seq numbers: 6589/126
            SPI underruns 4, overruns 4
            Number of disconnects: 0
            Buffer RX/TX: 0/0-0
            === Duet Control Server ===
            Duet Control Server v1.2.4.0
            Code buffer space: 2048
            Configured SPI speed: 2000000 Hz
            Full transfers per second: 28.59
            tobias_munich 1 Reply Last reply Reply Quote 0
            • jay_s_uk
              jay_s_uk last edited by
              Follow the information here https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
              to update the duet 3 using USB and Bossa
              • oliof
                @jay_s_uk and here I thought the raspberry pi and SPI connection would save me from BOSSA which always gives me trouble ...
                Also, interesting. On the pi:
                root@vcore-pro:~# dpkg -l reprapfirmware
                Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
                | Status=Nicht/Installiert/Config/U=Entpackt/halb konFiguriert/
                         Halb installiert/Trigger erWartet/Trigger anhängig
                |/ Fehler?=(kein)/R=Neuinstallation notwendig (Status, Fehler: GROSS=schlecht)
                ||/ Name           Version      Architektur  Beschreibung
                ii  reprapfirmware 1.2.4.0-1    all          RepRapFirmware Software Bundle
                root@vcore-pro:~# dpkg -L reprapfirmware
                /opt
                /opt/dsf
                /opt/dsf/sd
                /opt/dsf/sd/sys
                /opt/dsf/sd/sys/Duet3Bootloader_EXP.bin
                /opt/dsf/sd/sys/Duet3Bootloader_TOOL.bin
                /opt/dsf/sd/sys/Duet3Firmware_EXP3HC.bin
                /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
                /opt/dsf/sd/sys/Duet3Firmware_MBP05.bin
                /opt/dsf/sd/sys/Duet3Firmware_TOOL1LC.bin
                /opt/dsf/sd/sys/Duet3Firmware_TOOL1XD.bin
                /opt/dsf/sd/sys/Duet3_SBCiap_MB6HC.bin
                /opt/dsf/sd/sys/Duet3_SBCiap_MBP05.bin
                /opt/dsf/sd/sys/Duet3iap_spi_MB6HC.bin
                /opt/dsf/sd/sys/Duet3iap_spi_MBP05.bin
                root@vcore-pro:~# strings /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin | grep version=
                version=3.0
                root@vcore-pro:~#
                root@vcore-pro:~# shasum /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
                a2f94fe8a273f858ae88be9ddba6148bcadd47ca  /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
                root@vcore-pro:~# curl -sL -O https://github.com/dc42/RepRapFirmware/releases/download/3.0/Duet3Firmware_MB6HC.bin
                root@vcore-pro:~# shasum Duet3Firmware_MB6HC.bin
                a2f94fe8a273f858ae88be9ddba6148bcadd47ca  Duet3Firmware_MB6HC.bin
                So it looks like the 3.0 release is already on the SBC, but is not applied to the board.
                • tobias_munich
                  tobias_munich @oliof last edited by
                  This post is deleted!
                  • jay_s_uk
                    @oliof There were a few people that had issues updating from either a late alpha or early beta and the only way to get it to update was using Bossa.
                    Once you get to the latest version, you should have no issues going forwards
                    • oliof
                      OK. I tried to force a reinstallation of the reprapfirmware package and get an Invalid response from IAP:
                      root@vcore-pro:~# sudo apt-get install --reinstall reprapfirmware
                      Reading package lists... Done
                      Building dependency tree
                      Reading state information... Done
                      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                      Need to get 0 B/494 kB of archives.
                      After this operation, 0 B of additional disk space will be used.
                      (Reading database ... 77892 files and directories currently installed.)
                      Preparing to unpack .../reprapfirmware_1.2.4.0-1_all.deb ...
                      Unpacking reprapfirmware (1.2.4.0-1) over (1.2.4.0-1) ...
                      Setting up reprapfirmware (1.2.4.0-1) ...
                      Sending update request to DCS... Error: Failed to send update request
                      Unhandled exception. DuetAPIClient.Exceptions.InternalServerException: OperationCanceledException in Code: Invalid response from IAP
                         at DuetAPIClient.BaseConnection.PerformCommand[T](BaseCommand command, CancellationToken cancellationToken) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 189
                         at DuetControlServer.Program.CheckForAnotherInstance() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 216
                         at DuetControlServer.Program.Main(String[] args) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 63
                         at DuetControlServer.Program.<Main>(String[] args)
                      Aborted
                      root@vcore-pro:~#
                      I will try to update via BOSSA /-:
                      • tobias_munich
                        tobias_munich @oliof last edited by tobias_munich
                        path /home/christian/duet ? what's that ?
                        i am not using the SD card which was in the package of the board. I took the DuetPi image from here https://pkg.duet3d.com/DuetPi.zip.
                        the path should be /opt/dsf
                        • oliof
                          /home/christian/duet is whatever is compiled into the binary. The SDCard has DuetPi.
                          • oliof
                            BOSSA worked fine despite my anxiety about it:
                            M115
                            FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0
                            FIRMWARE_VERSION: 3.01-beta3 ELECTRONICS: Duet 3 MB6HC
                            FIRMWARE_DATE: 2020-01-29b1
                            Thanks everyone for their support!
