    How can I use my E1 heater as a pwn controlled fan port
    • maroonds
      maroonds last edited by maroonds
      that turns off when the extruder gets below 30 degrees? I'm on the latest RRF3.
      I'm trying this on my duet maestro.
      Any help is greatly appreciated.
        1. Use M950 to create a fan using the E1 heater output:. Assuming you already have fans 0, 1 and 2 then the next available is 3:
          M950 F3 C"e1heat"
        2. Use M106 in the normal way to make fan 3 thermostatic. If the hot end thermistor is configured as sensor 1:
          M106 P3 H1 T30 S1
        maroonds tekstyle 2 Replies Last reply Reply Quote 0
        • maroonds
          maroonds @dc42 last edited by
          @dc42 Thank you! But whats the polarity on those connectors?
          • droftarts
            droftarts administrators @maroonds last edited by
            @maroonds See https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram
            • tekstyle
              tekstyle @dc42 last edited by
              @dc42 said in How can I use my E1 heater as a pwn controlled fan port:
              1. Use M950 to create a fan using the E1 heater output:. Assuming you already have fans 90, 1 and 2 then the next available is 3:
                M950 F3 C"e1heat"
                M106 P3 H1 T30 S1
              In your example, what if I needed pwn1 as a fan port. Assuming I have fans 0,12,3,4,5,6,7,8. Do I do m950 F9 c"pwn1"
                If you mean duex.pwm1 then that port is shared with heater 3. You can use one or the other.
                tekstyle 1 Reply Last reply Reply Quote 0
                • tekstyle
                  I just realized it after reading through some more literature that it's either or. Thank you for confirming.
