    How do I assign a new part cooling fan?
    116
    • maroonds
      maroonds last edited by
      Hey! I'm having issues with my duet maestro firmware. My part cooling fan is connected to the FAN2 pin, but I'm only able to control it through this g-code: M106 P2 S255
      I would really like to have the slicer set the fan speed.
      I think this is the crucial part of my config.g:
      M950 F3 C"e1heat"
      M106 P3 H1 T35 S1
      M950 F2 C"fan2" Q500 ; create fan 0 on pin fan0 and set its frequency
      M106 P2 I0 C"5015" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F2 ; define tool 0
        The part cooling fan is usually Fan0 so that slicers that are unaware of multiple fan numbers can control it with simple M106 commands.
        So either set your slicer to use fan2, or reconfigure to use F0, etc instead.
        maroonds 1 Reply Last reply Reply Quote 1
        • maroonds
          maroonds @Phaedrux last edited by
          @Phaedrux How do I set up my slicer fan?
            Which slicer are you using?
            maroonds 1 Reply Last reply Reply Quote 0
            • maroonds
              @Phaedrux Prusa Slicer
                I don't think PrusaSlicer/Slic3r has the option of specifying a fan number, but you could use a post processing script to replace M160 with M106 P2, or open the gcode file in a text editor and do a find and replace.
                https://manual.slic3r.org/advanced/post-processing
                https://github.com/slic3r/Slic3r/wiki/Writing-post-processing-scripts
                https://reprap.org/forum/read.php?263,847419
                Or if that just seems far too complicated, you could just change your fan configuration to use F0 instead of F2
                M950 F0 C"fan2" Q500
                M106 P0 I0 C"5015" S0 H-1
                M563 P0 D0 H1 F0
                I think that should allow M106 commands without a P# to work.
                • maroonds
                  @Phaedrux I accidentally shorted my F0 port. That's why I'm having these issues in the first place. Thanks anyways:)
                    Phaedrux Moderator @maroonds last edited by
                    No no. It doesn't change the physical fan port. Just the fan number you're assigning to it.
                    C"fan2" refers to the port you're using. F0 makes it the default fan.
                    • maroonds
                      @Phaedrux Are you sure? Because I updated my config to:
                      M950 F3 C"e1heat"
                      M106 P3 H1 T35 S1
                      M563 P0 D0 H1 F0
                      And the fan still only activates when I type: M106 P2 S255
                        @maroonds said in How do I assign a new part cooling fan?:
                        Are you sure?
                        No, but I really thought that should work.
                        What firmware version are you using? Can you post your full config?
                        • maroonds
                          @Phaedrux Here's my config: https://pastebin.com/ePVM5nhm
                          I'm on the latest RR3 firmware.
                            Which version specifically?
                            • maroonds
                              @Phaedrux Board: Duet Maestro 1.0
                              Firmware: RepRapFirmware for Duet 2 Maestro 3.0 (2020-01-03b3)
                                In RRF 3.0 for the Maestro, fans 0, 1 and 2 are pre-allocated to "fan0", "fan1" and "fan2". So if you want to use different assignments such as:
                                then you need to remove the existing assignment to "fan2" by doing this first:
                                M950 F2 C"nil"
                                In RRF 3.01 the default fan assignments have been removed,
                                • maroonds
                                  maroonds @dc42 last edited by
                                  @dc42 said in How do I assign a new part cooling fan?:
                                  nil
                                  Like this? ; Fans
                                  M950 F3 C"e1heat"
                                  M106 P3 H1 T35 S1
                                  M950 F2 C"nil" Q500
                                  M563 P0 D0 H1 F0
                                  It's still not working.. I tried upgrading my firmware but I get this error: M997 S0
                                  Error: In-application programming binary "DuetMaestroIAP.bin" not found
                                    dc42 administrators @maroonds last edited by dc42
                                    nil
                                    Like this? ; Fans
                                    M950 F3 C"e1heat"
                                    M106 P3 H1 T35 S1
                                    M950 F2 C"nil" Q500
                                    No, you need to use M950 F2 C"nil" (to free up pin "fan2") and then M950 F0 C"fan2" Q500. Then you can use M106 P0 I0 C"5015" S0 H-1.
                                    M563 P0 D0 H1 F0
                                    You will find that file in the 3.0 release page on github.
                                    • maroonds
                                      Now it's working, thanks!
