    Updated Firmware Can't connect to it now
    Firmware installation
    wifi module duet 2 wifi
    556
    • chriskimbrundefined
      chriskimbr
      I have duet 2 wifi v2 with panelduo v2
      I updated the firmware to PanelDue-5.0i-7.0i.bin
      Nothing is working properly now.
      To begin with, it says wifi is connected,
      "WiFi module is connected to access point blablablaname, IP address 192.168.1.47.
      But I cannot connect to it from browser at all.
        Is the blue LED on the module lit?
          chriskimbr
          yes it is
            chriskimbr
            M115
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
            ok
              I think the only thing that changed when you updated the PanelDue is that it now has some popup messages at boot such as you saw about what AP you're connected to.
              With the wifi LED lit up, that would indicate that your config has M552 S1 in there to enable the module, and the connection popup would indicate that it's successfully connected to the AP.
              So what happens in the browser when you go to that 192.168.1.47 IP address?
              Are you able to ping that address from the command line?
              Are you able to check your router config page to see what is connected?
              chriskimbrundefined 2 Replies Last reply Reply Quote 0
                chriskimbr @Phaedrux
                @Phaedrux M503
                ; generated by RepRapFirmware Configuration Tool v2 on Sat Feb 09 2019 18:37:46 GMT+0000 (GMT)
                M667 S1 ; Select CoreXY mode
                M550 P"TronXY X5SA" ; Set machine name
                M552 S1 ; Enable network
                M586 P0 S1 ; Enable/Disable HTTP S0=disable S1=enable
                M586 P1 S1 ; Enable/Disable FTP
                M586 P2 S1 ; Enable/Disable Telnet
                M569 P0 S0 ; Drive 0 goes backwards
                M569 P3 S1 ; Drive 3 goes backwards
                M671 X421:-111.5 Y162:162 S5 ; leadscrews at mid left, and mid right
                M92 X80.00 Y80.00 Z100.00 E800 ;E1025 ; Set steps per mm
                M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                ;M203 X9000.00 Y9000.00 Z180.00 E1500.00 ; -origional- Set maximum speeds (mm/min)
                M203 X9000.00 Y9000.00 Z800.00 E700.00 ; Set maximum speeds (mm/min)
                ;M201 X3000.00 Y3000.00 Z250.00 E12000.00 ; Set accelerations (mm/s^2)
                M201 X3000.00 Y3000.00 Z250.00 E700.00
                ;M906 X1250.00 Y1250.00 Z1250.00 E1250.00 I30 ; -origional- Set motor currents (mA) and motor idle factor in per cent
                M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30
                M208 X0 Y0 Z-1.0 S1 ; Set axis minima
                M208 X330 Y330 Z400 S0 ; Set axis maxima
                M574 X1 Y1 S0 ; Set active high endstops
                M574 Z1 S2 ;Define Z to use Probe. Home to Min.
                ;M591 D0 P2 C3 S1 ; Filament sensor on for E0 extruder, simple NO switch connected to E0
                M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                M558 P9 H5 F120 T6000 ;last set >H20<, Set Z probe type to bltouch and the dive height + speeds
                G31 P25 X-20 Y-45 Z1.50; Set Z probe trigger value, offset and trigger height
                M557 X30:315 Y15:315 S130 ; Define mesh grid
                M305 P0 T100000 B4138 R4700 S"Bed Heater" ; Set thermistor + ADC parameters for heater 0
                M305 P1 T100000 B4725 C7.06e-8 R4700 S"Hot End Heater" ; Set thermistor + ADC parameters for heater 1
                ;M305 P1 T100000 B4138 R4700
                M106 P0 S0 I0 F500 H-1 ;Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M563 P0 D0 H1 ; Define tool 0
                M501 ; read eeprom parameters
                ok
                  @Phaedrux Pinging 192.168.1.47 with 32 bytes of data:
                  Reply from 192.168.1.47: bytes=32 time=4ms TTL=255
                  Reply from 192.168.1.47: bytes=32 time=23ms TTL=255
                  From console.
                  But chrome or ie i get "This site can’t be reached192.168.1.47 refused to connect."
                    chriskimbr
                    Its up now.
                    Not sure what made the difference.
                      So you've updated to firmware 3.0 as well?
                      Your config.g will need some substantial changes to work with RRF3.
                      I suggest either reverting to 2.05 (manually putting the firmware file on the SD card and sending the update command via the paneldue console)
                      Or if you intend to migrate to RRF3 generate a new config set using the web configurator.
                      chriskimbrundefined 1 Reply Last reply Reply Quote 0
                        @Phaedrux What do you reccomend? Is the 3.0 worth upgrading to?
                          Well it will be the way to go in the near future, but currently if all you want to do is print I would suggest sticking to 2.05.
