Dual Drive Extruder clicking. Extruder speed too high?
  • ; Configuration file for Duet WiFi (firmware version 1.21)
    ; generated by RepRapFirmware Configuration Tool v2 on Sat Feb 09 2019 18:37:46 GMT+0000 (GMT)
    M667 S1 ; Select CoreXY mode
    M550 P"TronXY X5SA" ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable/Disable HTTP S0=disable S1=enable
    M586 P1 S1 ; Enable/Disable FTP
    M586 P2 S1 ; Enable/Disable Telnet
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P3 S1 ; Drive 3 goes backwards
    M671 X421:-111.5 Y162:162 S5 ; leadscrews at mid left, and mid right
    M92 X80.00 Y80.00 Z100.00 E800 ;E1025 ; Set steps per mm
    M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
    ;M203 X9000.00 Y9000.00 Z180.00 E1500.00 ; -origional- Set maximum speeds (mm/min)
    M203 X9000.00 Y9000.00 Z800.00 E400.00 ; Set maximum speeds (mm/min)
    ;M201 X3000.00 Y3000.00 Z250.00 E12000.00 ; Set accelerations (mm/s^2)
    M201 X3000.00 Y3000.00 Z250.00 E400.00
    ;M906 X1250.00 Y1250.00 Z1250.00 E1250.00 I30 ; -origional- Set motor currents (mA) and motor idle factor in per cent
    M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30
    M208 X0 Y0 Z-1.0 S1 ; Set axis minima
    M208 X330 Y330 Z400 S0 ; Set axis maxima
    M574 X1 Y1 S0 ; Set active high endstops
    M574 Z1 S2 ;Define Z to use Probe. Home to Min.
    ;M591 D0 P2 C3 S1 ; Filament sensor on for E0 extruder, simple NO switch connected to E0
    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 ;last set >H20<, Set Z probe type to bltouch and the dive height + speeds
    G31 P25 X-20 Y-45 Z1.50; Set Z probe trigger value, offset and trigger height
    M557 X30:315 Y15:315 S130 ; Define mesh grid
    M305 P0 T100000 B4138 R4700 S"Bed Heater" ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C7.06e-8 R4700 S"Hot End Heater" ; Set thermistor + ADC parameters for heater 1
    ;M305 P1 T100000 B4138 R4700
    M106 P0 S0 I0 F500 H-1 ;Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 ; Define tool 0
    M501 ; read eeprom parameters
  • To calculate how fast your extruder motor is turning, the layer height, extrusion width, and feedrate are needed inputs.
    Also, can you describe clicking? Is the motor stalling? Is the drive gear slipping on the filament?
  • Moderator
    @chriskimbr said in Dual Drive Extruder clicking. Extruder speed too high?:
    Your previous acceleration for E was very high. The speed was fine. Now your speed is too low 400mm/min is only 6.6mm/s which would be very slow for retraction.
    Your extruder max speed should be as fast as your retraction speed. 6000mm/min for 100mm/s retraction max.
    The acceleration for E should be fine in the 2000-4000 range. 12000 is crazy high.
