Ir probe
Is it that green fibrous stuff?
I have used cork on my existing machine but was looking for any other alternative for the new one?
Doug
Sort of but it's more rigid. It's a sort of fibres glass mesh sandwich with the green fibre stuff as the filling. I can't find the exact board that I bought but this one looks the same. http://www.theunderfloorheatingstore.com/insulation-boards/electric/prowarm-trade-backer-pro-tile-backer-board. I think when I researched it that the thermal conductivity was much lower than the equivalent thickness of cork. My bed frame is 400mm x 400mm made of 2020 extrusion and I just laid the board on it and put the aluminium tooling plate on top and drilled through the whole lot. Being semi rigid, the insulation doesn't need glueing or anything to prevent it from sagging.
Apologies to the OP, we seem to have hijacked his thread.
ok how do i adjust the probe high from bed with out manly moving it i.e i want to make it closer
G31 P600 X0 Y0 Z1.50 ; Set Z probe trigger value, offset and trigger height
Adjust the Z value
yes i see now it stops at my set high 1.50 on home but gose to 0 when printing and i can still lower 0 with move keys my bad i see how it works now
is it possible to set up a 9 point bed meshing ?
