Problems with steppermotor
  • Hello i have a Problem with my Motors. I`m currently updating my anet E12 to a duet Wifi with Firmware3.
    All cables are connectet but when i press home z for example, the motor will turn a little bit in both direction and make horrible shatter noises.
    i dont now what kind of problem it is, maybe someone can help me.
    M122 say:
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
    Board ID: 08DJM-9178L-L2MSD-6JKD2-3SN6P-KTH2R
    Used output buffers: 1 of 24 (6 max)
    Static ram: 30516
    Dynamic ram: 91636 of which 32 recycled
    Exception stack ram used: 352
    Never used ram: 8536
    Tasks: NETWORK(ready,784) HEAT(blocked,1340) MAIN(running,3668) IDLE(ready,156)
    Owned mutexes:
    Last reset 00:05:29 ago, cause: software
    Last software reset at 2020-02-09 12:57, reason: User, spinning module GCodes, available RAM 8492 bytes (slot 3)
    Error status: 0
    Free file entries: 10
    MCU temperature: min 24.4, current 25.0, max 25.5
    Supply voltage: min 12.7, current 12.8, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
    Cache data hit count 902593050
    Slowest loop: 9.13ms; fastest: 0.09ms
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 168, MaxWait: 8317ms
    === MainDDARing ===
    Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.52ms; fastest: 0.00ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 1 of 8
  • Also with one Firmware i was able to move one motor but since i change something nothing will work anymore
  • please post your config.g and your homing files
  • Config :
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 09 2020 12:48:51 GMT+0100 (Mitteleuropäische Normalzeit)
    M550 P"Anet E12" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X310 Y310 Z400 S0 ; set axis maxima
    M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T18000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; define mesh grid
    Homing:
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 H2 Z5 F18000 ; lift Z relative to current position
    G1 H1 X-315 Y-315 F1200 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F18000 ; go back a few mm
    G1 H1 X-315 Y-315 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G1 H1 Z-405 F360 ; move Z down stopping at the endstop
    G90 ; absolute positioning
    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    ;G91 ; relative positioning
    ;G1 Z5 F300 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • duble check your wires, did you get some error messages in the console if you try to home your printer ?
    Most likely you don't have the stepper motor wires correctly phased (CAUTION: this can damage the drivers!), or there is a bad connection in one wire.
  • I think all wires a correct connectet. in other orientations the stepper does nothing at all. And then i get a error message, but not when the stepper stutters
    is there a way to check if the drivers a damaged?
  • @MauriceM said in Problems with steppermotor:
    you can swap the drivers change the wiring lets say swap x and y and add M584 X1 Y0 Z2 E3 ; set drive mapping and try again.
  • So i achieved that all motors turn except the z motors
    It was a cable Problem, i hope i didnt demaged the z drivers
  • Thanks Guys, now it works , i bought cables with different colour matching. Was a stupid mistake but i damaged nothing and now i can enjoy my silent printer.
    @MauriceM, I'm glad it all worked out for you and didn't cause any damage. Unfortunately, for stepper motors that have 6-pin JST connectors on them, there are at least 2 different pinouts used. So you can't rely on the wire colours being correct, especially if the motors and cables were purchased for different suppliers.
    Can you tell us what VIN voltage you used, and what type of motors? Did you get any "short to ground" warnings from the firmware? I'd like to get a better idea of when the internal short circuit protection in the drivers works.
  • VIN in 12.5V and the type of Motor is: 42SHDC3025-24B.
    But i never had a short to ground issue.
