    Stallguard not working
    995
    • xorloschundefined
      xorlosch
      I have a lot of problems with line skipping after i changed the board of my ridigdbot to the duet. with the rigdigbot that was a common error because the stepper driver overheated and then turned off. I think that should not be a problem with the duet and the little current i am pulling? I also tried to get the stall detection to work but I am unable to get it to trigger (not even with M915 P0:1 S-10 F1 R3)
      Is there a trick? Can sombody post a working config.g example code for a carthesian printer? ( I am not trying them as home switches mind you, I just want it to trigger the rehoming file when printing and skipping).
      I have mostly skipping in the X-axis. and am using two zmotors(just to make my settings understandable)
      My motor settings are :
      M584 X0 Y1 Z2:4 E3 ; set drive mapping
      ;M350 Y8 I0 ; configure microstepping without interpolation
      M92 X44.31 Y44.30 Z1590.98 E409.0 ; set steps per mm Y22.15
      M566 X300.00 Y300.00 Z24.00 E20.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z240.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y600.00 Z100.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X900 Y1200 Z1100 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30
      M915 P0:1 S5 F1 R3 ;Stalldetection
      And the rehome.g contains:
      G91 ; relative positioning
      ;G1 H2 Z5 F6000 ; lift Z relative to current position
      G1 H1 X-259 Y-250 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-259 Y-250 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      ;G1 H2 Z-5 F6000 ; lower Z again
      I tried different motor settings (more and less current) and also to stall the motor while printing ( as I read stall detection might not be active in manual mode). And also with the diferent R settings. But no luck, no message, no homing, nothing. is mikrostepping not allowed for the stallguard? Am I running the wrong firmware? (mine is 2.1 beta, if i remember correctly)
      Thanks for any helpful tips 🙂
        You don't mention which board you're actually using. If it's the Maestro, it does not support stall detection with the 2224 drivers. If it's a wifi/ethernet then it does.
        Have you seen this? https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
        For firmware you should use this one: https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
        you'll need Duet2CombinedFirmware.bin, Duet2CombinedFirmware.bin, and DuetWiFiServer-1.23.bin.
        For motor current you should target 70 to 85% of the rated max of the motor.
        • xorloschundefined
          xorlosch
          Ah, thanks. Sorry I forgot to mention: I am using a Duet Wifi.
          My firmware is this one:
          Firmware Version: 2.03beta1 (2019-02-03b3)
          So maybe it does not work with my version? I will try to update the Frimware next then
            It should work, but yes, would be best to update.
            Also re-read the stall detection page and see if you are running into any of the limitations noted there.
            xorloschundefined 1 Reply Last reply Reply Quote 0
            • xorloschundefined
              xorlosch @Phaedrux
              Still not working after the update. I also reread the webpage how to set the stall detection up several times aready but it just won't activate. but maybe I have to increase the current of the motors a bit more ( I was just running at 70%). is there something else which could be wrong? Having the M915 command at the end of config.g is ok, or does it need a special place to be?
                Having M915 in config.g should be fine.
                Can you send M915 in the console by itself and see what it reports back just to confirm it's settings are actually being applied?
                  How fast are you moving when you're trying to trigger it?
                    Phaedrux Moderator @xorlosch
                    @xorlosch said in Stallguard not working:
                    M92 X44.31 Y44.30
                    I wonder if the low steps per mm on X and Y would have something to do with it? @dc42
                    • xorloschundefined
                      xorlosch
                      The command is applied. I now try M915 X Y S-50 F1 R2. That should trigger on anything hopefully and then stop the print. how fast I a going is a loaded question. As far as I understood this only works while printing, so I set it u to print something. max speed should be 50 I think. lowest speed?
                        Ok, so just to confirm, you are testing it during an actual print? As far as I recall that's really the only way it will work.
                        Have you experimented with the H parameter yet?
                        Hnnn (optional) Minimum motor full steps per second for stall detection to be considered reliable, default 200 (try 400 for 0.9deg motors)
                        I think this may be where your low steps per mm on X and Y may be coming into play.
                        • xorloschundefined
                          xorlosch
                          the low settings for M92 X and Y should be quite typically for a belt driven carthesian printer. but maybe that is the problem. I just tried again and it still won't register. maybe also my current reduction to 30% is at fault. Or my jerk and acceleartion settings. I give up for now. maybe i can get it to stopp skipping layers by crancking up the current(which my last board did). Or I have to stop using mikrostepping, as that also seem to loose some torque for the single steps
                          • xorloschundefined
                            xorlosch
                            As I understood the H settings are to prevent too many wrong triggers. Of course I could try to reduce it but 200 (which is also the dfault) should be the correct settings for my motors. And Yes: I started a print ech time I tested if the stal detection was working
                            • xorloschundefined
                              xorlosch
                              but now that I think about it , that might be what stops me here, as the direct driven belts have the low steps per mm values, I might have been slightly below that vaue of 200 steps /s
                                That's what I mean. Try setting it lower. 100 or even 50 just to see if you can even get a trigger.
                                You're only using 30% current?
                                • xorloschundefined
                                  xorlosch
                                  Ok that worked. I went to an agressive S-50 H10 and it instantly triggered. So now I have a at least a starting point for finetuning. I will post my settings when i am done (in the next days).
                                  30% I had as reduced power for my stepper motors :M906 X1050 Y1250 Z1100 E900 I30
                                  would that be too low?
                                    Do you mean the I30? That's for idle hold, not normal operation.
                                    The current for X Y and Z look reasonable, but as I said earlier. Target 70-85% of the max for the motor.
                                    • xorloschundefined
                                      xorlosch
                                      yes those values I had both set to 70%. now i increased to 82%
                                      • xorloschundefined
                                        xorlosch
                                        I tried setting up the stall detection but the axis is just too slow for stallguard to work. seems to be better suited for delta printers or core xy than carthesian printers :(. I had to go lower than H50 to detect stalls and then acutally all o them were false and it did not trigger on any real stalls. I will try installing smaller toothed gears for te belts (so that the motor neeeds more stes per mm) but i don't have high hopes. Has anybody got the Stall detection to work with carthesian printer with ow steps per turn?
                                          What was the S value?
                                          • xorloschundefined
                                            xorlosch @Phaedrux
                                            @Phaedrux with an S value of 7 or lower i detect a lot of false stalls. with a higher vslue i detect no stalls. but eitherway with both higher and lower s values (as low as 3) i could not detect real stalls.
