    Stallguard not working
    1.0k
      droftarts administrators @xorlosch
      @xorlosch Bearing in mind the limitations of stall detection https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Limitations_of_stall_detection
      • What motors do you have? Are they high inductance?
      • What speeds are you trying to measure? What is your standard printing/travel speeds?
      With you X and Y steps of 44.3 steps per mm (which is pretty low, nowadays), and 16x microstepping, this means you get 2.769 FULL steps per mm. If you're printing/moving at 50mm/s, that's 138 full steps per second, which is under the default H parameter of 200 full steps per second. You would need to move at 73mm/s to hit this. An H value of 50 is 18mm/s, which seems very slow, and is unlikely to produce good results. Are you really moving the axes this slow? Try reducing your accelerations (M201) to see if that helps.
      You could increase the full steps per mm by changing pulleys, as you've suggested, changing motors to 0.9º step angle motors, or use a gearbox on the motors. It just depends how important Stallguard is to you, and how much you're willing to spend to get it working!
      xorloschundefined 1 Reply Last reply Reply Quote 0
      • xorloschundefined
        xorlosch @droftarts
        @droftarts : not quite sure what the inductance of the motors is, but it really seems like the low speed is the problem here. As I mentioned the frame and motors of my printer are still the original Ridgidbot, which had some... let's say interesting design choices ;). The X and Y axis were using huge 36 tooth gears (with 2mm width gives about full 2,78 steps/mm). I acutally had bought allready smaller belt gears with 16 tooth but with the old ridgidbot overheating was the bigger problem so i skipped installing those.
        But now I will for sure install those! That should bring me then up to 6.25 steps/mm which would corespond to 32mm/s for a reasonable H value of 200. Am I correct? I hope that will work better then. (Which it should as then the motors have more torque at the same time also with the smaller bet gears)
        Just for interest: how many full steps does your cartesian printer use per mm?
          @xorlosch said in Stallguard not working:
          The ender 3 for instance uses 80 steps per mm on X and Y. And that's 200 steps per rev motors, x16 microstepping, 20 tooth pulleys, and 2mm belt pitch. If you used 400 steps per rev motors or 16 tooth pulleys it's up to 200.
            @xorlosch my Cartesian machine uses T2.5 belt with 16 tooth pulleys, 16x microstepping, 1.8 degree motors, for 80 steps per mm, or 5 full steps per mm. I usually print at 50mm/s max, and a lot of moves are half that speed. 40mm/s would be the target speed with this setup and H=200, but I’d probably have to drop H to 100. But I also haven’t set up stallgaurd to try it out! Perhaps tomorrow...
            • xorloschundefined
              xorlosch
              Thanks. Then it sound as if we are in the same ballpark at least. I also could find an old datasheet in the net for my motor: it has 2.5mH per phase.
              I actually like to print as fast as i can ;). In the past with the original setup i pushed up to 100 mm/s. But right after switching over to the Duet wifi I never quite got it back to work again as good as before ( I think the motors were runing near their current limit before). Still some tuning to do. Small prints are fine now, but with even midsize prints I get now all those layer shifts and that is why i was trying to get the Stall guard activated. And more torque will help me too 😉
