    Can i use pinda v2 connect to E1 endstop?
    Filament Monitor
    112
    • daxzero
      daxzero last edited by
      pinda v2
      duet 2 wifi
        I am not familiar with the Pinda but i think it is an NPN sensor with added thermistor. In which case you should be able to connect it to either the Z probe input or an endstop input.
          https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
          • Veti
            Veti last edited by
            @daxzero said in Can i use pinda v2 connect to E1 endstop?:
            can you elaborate as to what you want to do?
            i am assuming you want to set up a second probe?
            • inztigator
              inztigator last edited by inztigator
              You can, if you mean as a z-endstop. I use it on my CoreXY. Works quite well. Its just an inductive sensor. You don't connect the temperature wire as you would on a Prusa. I believe that may be supported in RRF3 if I remember correctly.
              Can send you a photo of the wiring when I get home, and config 😉
              misc 1 Reply Last reply Reply Quote 0
              • misc
                misc @inztigator last edited by
                @inztigator Would you please show us, how you connect the pinda to the duet board? Thanks a lot
                Michael
                • hmmatos
                  hmmatos last edited by
                  @inztigator did it work? did you connect the PINDA to the E1 endstop?
                  Thanks
                  • hmmatos
                    Hi, in case of anyone needs I have connected like this:
                    it works very well
