    New repository for machine configuration files
    781
      I have created a repository at https://github.com/Duet3D/RRF-machine-config-files to host configuration and related files for RepRapFirmware. User contributions are encouraged. See the README file there for more details.
      1 Reply Last reply Reply Quote 11
      • Danalundefined
        Danal
        Great idea! Bravo!!
        • OBELIKSundefined
          OBELIKS
          Would it make sense to remove the values from M143, M906 and M208 and put them to the comment for these lines?
          That way there would be no way of someone running an incompatible config. Mistakes happen, you can miss something and get in to trouble.
          P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
          Original Prusa i3 MK3S
          • Ntrackundefined
            Ntrack
            Github is for people smarter than me . Here's a link for MMU running on RRF 3.01 for a cartesian printer . Easy to modify it to work on other motion systems. Someone may be able to put that on github.
              Phaedrux Moderator @Ntrack
              @Ntrack I can put it on github along with my own configs once I get them cleaned up.
              Ntrackundefined 1 Reply Last reply Reply Quote 0
              • Ntrackundefined
                Ntrack @Phaedrux
                @Phaedrux Thank you
                  dc42 administrators @OBELIKS
                  @OBELIKS said in New repository for machine configuration files:
                  We decided not to do that, because many of the config file sets will be for standard machines. The repository readme file warns users to check M143 and M906 commands specifically.
                  • OBELIKSundefined
                    OBELIKS
                    Ah, that makes sense.
