Problems with XY Homing
Good Morning,i have Problems to home my X and Y axis. The LED on the board is not on, but the board thinks the endstop is triggered.
So if i want to home e.g X the carriage will move some mm to one side and than says that it is homed. But when i close the endstop and home X, the printer wants to home untill i release the endstop.
I tried all Possible configuration and i dont now what im doing wrong.
I have 2 phases Endstops, i dont now if they are NO ore NC. I trief both configuration but nothing worked.
H had the same problem with the Z axis until i added I1 in config.g for Z Probe, but that didnt worked for the other axis.
Config.g:
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 11 2020 10:36:53 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"Anet E12" ; set printer name; Drives
M569 P0 S0 ; physical drive 0 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X310 Y310 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"zprobe.in+zprobe.mod" H5 F120 T6000 I1 ; set Z probe type to switch and the dive height + speeds
G31 P500 X25 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:290 Y15:290 S20 ; define mesh grid; Heaters
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
@MauriceM I sounds like you need to invert the input. It also looks like you using RRF3 so the "I" parameter won't work. Instead you need to put "!" before the pin name. So M574 X1 S1 P"!xstop" instead of M574 X1 S1 P"xstop"
@MauriceM said in Problems with XY Homing:
M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystoptry to invert your endstops with:
M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop -
Thanks, it workes flawless. now i have to change the motor to the right direction and it will work.
But why did the I1 on the Z Probe worked? bevor that change the z probe was also triggered the whole time.
Currently, the I parameter on the M558 command is still supported, but it will probably be removed in a future firmware version.
it seems that this is not removed in rrf3 if you want to make it right then add ! and remove I1 to this line
M558 P5 C"!zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds -
Ah ok, i will change it. Thanks
If you're using the Z probe for homing Z, and have no endstop, this should be
M574 Z0
.Ian
but its working so i dont have to change it or will it cause problems?
@MauriceM It's fine to leave it if you home Z using G30. But if, by mistake, you try using (or your homing.g files contain) a G1 H1 (ie a homing move) on Z, it will try to use the non-existant endstop, rather than the probe, to home Z, resulting in a crash. Better to remove the chance!
