Stepper motors ports Duex5 seem to not respond anymore
Hey all,
I've been using DuetWifi2 and Duex5 for months for a big 3D printer homemade, and it worked perfectly until now. For some months we changed some 3D printed parts and unplugged / plugged again some wires. Now we're back to test the movement, and the whole ports linked to the stepper motors on the Duex are not responding anymore (the motors don't move).
We tried exchanging the motors connected on the DuetWifi with the one on the Duex. The 2 motors that were working right before connected on DuetWifi don't work anymore when connected to the Duex. We also tried to move the motors from drive 7/8 to drive 5/6 (and adapting on the firmware of course), and these two don't work either.
It seems to us that the whole left part of the Duex is not working anymore, but we can't get why. We have a BLTouch connected to the Duex and it works, so it's not the Duex itself, at least not all of it. Is it possible that the whole part linked to the stepper motors is dead ? Is there any kind of security that could have been activated because one port is possibly dead?
Thank you so much for any suggestions...
Have a nice day !
did you get a error message in the console if you try to move a stepper which is connected to the duex board?
Enter M122 in the console and post the result here Please and can you post your config.g file
Vin on the duex is connected and have power? -
No we don't have any error message, nothing. It's just that half of the motors are not moving (the ones on the Duex5 board).
The M122 command gave us this :
Diagnostics
ReprapFirmware for Duet 2
Wifi/Ethernet version 2.0(RTOS) running on Duet Wifi 1.02 or later + Duex Board ID: 08DGM-9T6BU-FG3S0-7J1F2-3S46JThe config.g file is like this :
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 11 2020 18:16:38 GMT+0100 (Central European Standard Time); General preferences
M550 P"BigPrinter 2.10" ; set printer name
M564 H0 ; allow motors to move without homing first; Network
M551 P"1234" ; set password
M552 P0.0.0.0 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X88.89 Y88.89 Z1600.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z1200 E800 I0 ; set motor currents (mA) and motor idle factor in per cent
M208 X200 Y160 Z0 S1 ; set axis minima
M208 X600 Y620 Z700 S0 ; set axis maxima; Endstops
M574 X1 Y1 S1 ; set active high endstops
M574 Z2 S2 ; set endstops controlled by probe; Z-Probe
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T3000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y52 Z1.6 ; set Z probe trigger value, offset and trigger height
M557 X250:550 Y210:580 S75 ; define mesh grid; Heaters
M140 H-1 ; disable heated bed
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S1 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T50 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"test" D0 H1 F0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M584 X0:9 ; Two X motors on driver 0(default) and 9 of duex
M569 P9 S0 ; Change direction of one motor
M569 P7 S1 ; Change direction of Z motor
M569 P8 S1
M584 Z2:5:6 ; Set 4 motors on ZVin is connected and do have power, the leds are lightning on at the power up of the printer, and the BL touch connected to the Duex is perfectly working...
Thanks for you help and looking forward to your answer
the first thing is your custom settings:
Order dependence
M584 must come earlier in config.g than any M350 and M906 commands. If it creates new axes, it must also be earlier than any M92, M201, M203, M208, M350, M566, M574, M667 and M669 commands.
please solve this and test again.
I tried moving the two M584 commands in the begginning of the file : still same results.
you will use port 5 & 6 on your duex but the m569 p5 & p6 is missing and you write as commend that you have 4 Z motors there are only 3 configured
Actually at the begginning we were working with ports 7 and 8 for the other motors, and now we are back to it (so the M569 P7 and P8 code).
Isn't it normal that only 3 motors appear, as on the drive 2 you can have two different motors ? The total is 4 motors...
We think that the problem is linked to an update on the Firmware (in september 2019?)... The Duex is recognized but the information is not driven into the motors.
@PaulineC said in Stepper motors ports Duex5 seem to not respond anymore:
is it possible that you update your firmware to the latest 2.5.1 (not 3.0!) and then post the result of m122 again
I don't see 2.5.1 in the possibilities. We updated the firmware to 2.0 yesterday and it changed nothing :
you'll find the firmware here
https://forum.duet3d.com/topic/14310/reprapfirmware-2-05-1-duet-2-and-1-26-1-duet-06-085-released/1?_=1581494521559and for the configurator 2.03 to 2.05 would be the one to use after updating the firmware first.
@bearer Thank you yes, we downloaded the firmware from here yesterday.
I'll do the M115 command as soon as I get back to the printer in some minutes, and will update the situation.Actually we didn't work on the firmware since june 19, so we were working with 1.21 and everything was ok. I believe now we need to update
Okay so did the M115 command, and even if i downloaded the file of the new firmware and put it into the sys file, but it still returns that :
Reprapfirmware for Duet2 Wifi/Ethernet Version 2.0 (RTOS) running on Duet Wifi 1.02 or later + DueX5 Board ID...The update is in a way that I don't get, not working
there are a few files that have changed names along the way, so either search the forum for the details, read the whats new file or update the board using usb and bossa.
@PaulineC Just downloading the file and putting it in the sys folder may not update the firmware. If it doesn't, you need to send command
M997 S0
to install the firmware.Ian
@droftarts also hasn't the IAP File changed between 2.0 and 2.05 (not sure but I believe it has I have moved to V3 a fair while ago now).
Doug
@Dougal1957 May have done, but will only need to update that if @PaulineC wants to downgrade back to earlier firmware from 2.05.1. We'll see if they get an error trying to update, as they were on 1.21 before, updated to 2.0.
@PaulineC For your config.g, you should define all the motors with M569 and set them for each axis with M584, before setting motor speeds and accelerations. Below is a version of your config.g done like this, without the 'Custom settings' section at the end. Also, it would be best to put motors that are on the same axis on the same board (Duet or DueX), eg
M584 X0:1 Y:2 E:3, Z:5:6:7
. I have not done this below.; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 11 2020 18:16:38 GMT+0100 (Central European Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"BigPrinter 2.10" ; set printer name M564 H0 ; allow motors to move without homing first ; Network M551 P"1234" ; set password M552 P0.0.0.0 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M569 P5 S1 ; physical drive 5 goes forwards M569 P6 S1 ; physical drive 6 goes forwards M569 P7 S1 ; Change direction of Z motor M569 P8 S1 ; physical drive 8 goes forwards M569 P9 S0 ; Change direction of one motor ; Old settings ;M584 X0 Y1 Z2 E3 ; set drive mapping (original) ;M584 X0:9 ; Two X motors on driver 0(default) and 9 of duex ;M584 Z2:5:6 ; Set 4 motors on Z M584 X0:9 Y1 Z2:5:6 E3 ; M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X88.89 Y88.89 Z1600.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1200 E800 I0 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X200 Y160 Z0 S1 ; set axis minima M208 X600 Y620 Z700 S0 ; set axis maxima ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z2 S2 ; set endstops controlled by probe ; Z-Probe M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H5 F120 T3000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y52 Z1.6 ; set Z probe trigger value, offset and trigger height M557 X250:550 Y210:580 S75 ; define mesh grid ; Heaters M140 H-1 ; disable heated bed M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S1 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T50 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 S"test" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
Try this, let me know what works.
@droftarts Thanks for the information about the M997 command, it worked perfectly fine and now we're running 2.0.5. Unfortunately, it changed nothing. I'll try using the rework of the config.g file that you just sent, thank you !
Pauline
@PaulineC Can you check if the Duex is getting power at the screw terminals with a voltmeter? Check the connections; see: https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
The Duet is seeing the Duex, because in the response to
M115
you get:
So it may just be a power issue. Also check jumpers on the DueX; see https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_JumpersOtherwise, please can you post a picture showing the Duet, Duex and wiring.
