    Heater temperature lower limit override
    • siriltejadundefined
      siriltejad
      I am facing issues when I am trying to extrude the filament at lower temperatures.
      I have some custom materials that should be extruded at 120 degrees. But the printer won't let me do that. I'm guessing there is a safety lock on temperature while extrusion.
      Can i change the lower limit so that i can extrude at 120 degrees. Where can I change the lower limit.
      • A Former User?
        A Former User
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
