Rat rig v-core pro COREXYU
@neetspeed said in Rat rig v-core pro COREXYU:
I think the flash I found the same problem on youtube
je pense le flasher j'ai trouvé le meme probleme sur youtube
From the linked thread for that video they eventually used a windows PC to flash.
But if you're using a mac, check this out on getting bossa working in recent macOS versions. https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x?_=1581893503158
PanelDue Failure
je pense le flasher j'ai trouvé le meme probleme sur youtubeOui.
Si vous ne souhaitez pas utiliser votre Mac, Un Raspberry Pi peut également flasher via bossa.
bossa installer:
sudo apt update && sudo apt install -y libwxgtk3.0-dev libreadline-dev git clone https://github.com/shumatech/BOSSA cd BOSSA make - Connectez le panneau à Pi avec un câble USB
wget https://github.com/dc42/PanelDueFirmware/releases/download/1.23.2/PanelDue-v3-4.3.bin
~/BOSSA/bin/bossac -e -w -v -b PanelDue-v3-4.3.bin
Devrait fonctionner en moins de deux minutes. Si cela ne fixe pas le panneau, faites de même avec 'PanelDue-v2-7.0C.bin'
And please forgive any of my very rusty french...
it's good flash ok,
with PanelDue-v3-7.0E.bin,
everything is ok, he became himself again,
I had to stay press on erase I don't know?
I'm on windows,
but its going to be useful to the people who follow and who are equip apple.
thank you
I can return following my projectc bon flashe ok ,
avec PanelDue-v3-7.0E.bin ,
tout est ok , il est redevenu lui meme ,
j'avais du rester apuyer sur erase je sais pas ?
je suis sous windows ,
mais sa va servir aux personnes qui suivent et qui sont equiper apple .
merci
je peux retourner a la suite de mon projet -
Hello .
I receive my pieces little by little, it will soon be big big job,
I especially expect the aluminum and the linear rail, the I connect all the electronics etc etc. but I have questions
the stepper motor 0.9 degree, I just have to double the steps or I change another parameter? (compared to 1.8 degrees)
i will need a total of 6 nema stepper motor,
2 Z, 1 X, 1 Y, 1U (if I understood correctly for idex)
and 2 for the extruder,
I am obliged to take the extension duex, for an additional nema, or I have another way, its makes me expensive the extension for a single stepper motor, even if I have a lot of possibilities after
.Salut .
Je reçois mes pièces petit à petit, ce sera bientôt un gros gros boulot :),
J'attends surtout l'aluminium et le rail linéaire, le je connecte toute l'électronique etc etc mais j'ai des questions??
le moteur pas à pas 0,9 degré, je dois juste doubler les pas ou je change un autre paramètre? (par rapport à 1,8 degrés)
j'aurai besoin d'un total de 6 moteurs pas à pas nema,
2 Z, 1 X, 1 Y, 1U (si j'ai bien compris pour idex)
et 2 pour l'extrudeuse,
Je suis obligé de prendre l'extension duex, pour un nema supplémentaire, ou j'ai un autre moyen, ça me coûte cher l'extension pour un seul moteur pas à pas, même si j'ai beaucoup de possibilités après
That's correct. You would need to double the steps per mm compared to 1.8 degree motors.
Thank you
and for the additional stepper motor,
duex extention compulsory?
or can i find something else?Je vous remercie
et pour le moteur pas à pas supplémentaire,
duex extension obligatoire?
ou puis-je trouver autre chose? -
I think in your case the duex would be the best option
You could setup initially with just the Duet Wifi and it's 5 drivers and get the CoreXY working. Then you can decide after how many motors you would need for your IDEX build. Or are you planning and going straight to the IDEX build?
The Duet Wifi has 5 drivers. The Duex2 has an additional 2 drivers, and the Duex5 has 5 more drivers.
I would plan for 3 Z motors to do auto bed leveling, 2 extruders, and then perhaps up to 4 more motors depending on what your CoreXY IDEX arrangement ends up being.
thank you so much for your help,
yes exactly I'm going to mount everything in corexy, and start to prepare everything for the additional chario.
I have only 2 stepper motor for z, so duet2 wifi 5 motor available, I need the extension duex5 in my opinion as its I would be good to add the 3rd stepper motor on z, and I add my missing extruder for chario idex, and i will be ready for the future i thinkmerci énormement pour votre aide,
oui exactement je vais tout monter en corexy, et comencer a tout preparer pour la chario suplementaire.
j'ai que 2 moteur pas a pas pour z, alors duet2 wifi 5 moteur disponible, il me faut l'extention duex5 a mon avis comme sa je serai bien pour rajouter le 3 eme moteur pas a pas sur z, et moi rajouter mon extrudeur manquant pour le chario idex, et je serai parer pour l'avenir je pensse -
Hi
good i got my duex5 and everything else i continue my project,
but I have a blockage
it makes me crazy twice I change the bl touch I configure everything,
it comes in it goes out, upon ignition then nothing.
the z burst my 7 inch paneldue,
pff i have more strength
I have more than her to conquer to pass to the additional axis usalut
bon jai recu ma duex5 et tout le reste je continu mon projet ,
mais la jai un bloquage
ça me rend dingue deux fois je change le bl touch je configure tout ,
il rentre il sort , a l'alumage puis plus rien .
le z ma eclater un paneldue 7 pouce ,
pff j'ai plus de force
il me reste plus que sa de conpliquer pour paser a l'axe u suplementaire -
Hi friends
I explain my problem, the bltouch seems to work, it is triggered when the machine is switched on (ignition, up and down)
tests them it responds when I ask it to go up or down,
but when I run home,
xy correctly, but Z rises slightly then descends without ever stopping,
I manually operate the bltouche change nothing even if the sense of motor is not correct it should stop right?
I have an error the Z probe was not triggered at the surveyI don't know what to do I'm lost I keep looking
Thanks for your helpsalut les amis
J'explique mon problème, le bltouch semble fonctionner, il se déclenche lorsque la machine est allumée (allumage, haut et bas)
les teste, il répond quand je lui demande de monter ou de descendre,
mais quand je rentre chez moi,
xy correctement, mais Z monte légèrement puis descend sans jamais s'arrêter,
J'utilise manuellement le bltouche ne change rien même si le sens du moteur n'est pas correct il faut s'arrêter non?
J'ai une erreur, la sonde Z n'a pas été déclenchée lors de l'enquêteJe ne sais pas quoi faire, je suis perdu, je continue de chercher
Merci de votre aideconfig (2).g -
Post your homeall as well.
ok merci
homeall.g -
Your config and homeall look ok. It sounds like the white signal wire is not making connection. Check your wiring again. Try re-crimping. Check for breaks.
thank you
you are a champion
I had 2 problem, the engine reverse I suspected,
and malge my tests on the wiring, actually when the chario was moving I had a false contact o white wireMerci
tu es un champion
J'ai eu 2 problèmes, le moteur inversé je le soupçonnais,
et malge mes tests sur le câblage, en fait quand le chario se déplaçait j'avais un faux contact o un fil blanc -
Have you seen this page for corexy commissioning?
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter -
Yes thanks
I leaf through them,
everything is fine in the X Y movements,
I had a problem with Z sa seems to be resolved,
I cable everything, I pass the cable chain, included for the U axis carriage
and as soon as everything goes well for core xy I pass to the addition of U,
I have an additional manipulation to indicate u in markforged mode ??
or am I just adding an additional axis?
thank youOui merci
Je les feuillette,
tout va bien dans les mouvements X Y,
J'ai eu un problème avec Z sa semble être résolu,
Je câble tout, je passe la chaîne de câbles, incluse pour le chariot de l'axe U
et dès que tout se passe bien pour le noyau xy je passe à l'ajout de U,
J'ai une manipulation supplémentaire pour indiquer u en mode markforged ??
ou est-ce que j'ajoute juste un axe supplémentaire?
Merci -
hi friends
everything seems to work, except the Z bed which is difficult to synchronize I try to manage to separate the driver and automatic level correction,
and still no news for the addition of mark forged chariosalut les amis
tout semble fonctionner, sauf le lit Z qui est difficile à synchroniser j'essaye de réussir à séparer le driver et la correction automatique du niveau,
et toujours pas de nouvelles pour l'ajout de marque forgé chario -
Have you seen this?
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
As for the IDEX markforged kinematics I have no idea.
