    No output from G32 on DSF 1.2.4 / DWC 2.07
    Duet Web Control
    14
    64
    3.6k
    • PaulHewundefined
      PaulHew
      Re-ran Mesh Compensation and still will not display height map.
      File is there
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • PaulHewundefined
        PaulHew
        @chrishamm
        Update, put DWC2.0.7 back on and height map is displayed.
        Regards,
        Paul
        PaulHewundefined 1 Reply Last reply Reply Quote 0
        • PaulHewundefined
          PaulHew @PaulHew
          @chrishamm
          All fixed with 2.1.1 Thank you.
          • chrishammundefined
            chrishamm administrators
            Glad it's working now. The issue with G32 not showing any output should be fixed in DSF 1.3.1, too.
            Duet software engineer
            mvieleersundefined 1 Reply Last reply Reply Quote 1
            • kraegarundefined
              kraegar
              @chrishamm said in No output from G32 on DSF 1.2.4 / DWC 2.07:
              Great news. I'll have to stop printing face shields long enough to upgrade and test!
              Co-Creator of the RailcoreII CoreXY printer
              https://www.thingiverse.com/thing:2407174
              • Danalundefined
                Danal
                Yay!! I'm still new with 3 motor beds, and it really helps to see the output. Yay!!
                kraegarundefined 1 Reply Last reply Reply Quote 0
                • kraegarundefined
                  kraegar @Danal
                  @Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                  I strongly recommend using a script to auto level until it's under a set value, with a Z home at the end. I've been doing that with one of my printers, and it's been awesome. The other day I had a bit of filament stuck right where my probe hits one spot, and so it couldn't level correctly. It failed to level under my set value, so I went to check and found the filament. Might have saved me a bed surface!
                  • Danalundefined
                    Danal
                    @kraegar said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                    That is exactly what I do. And check the console output to see that it is converging.
                    Literally called "prepz.g"
                    • mvieleersundefined
                      mvieleers @chrishamm
                      @chrishamm This is indeed correctly working now in DSF 1.3.1. Great job! Thanks! As this was the original issue, I guess this topic can be closed now.
                        @chrishamm Just to make sure I'm not doing anything wrong...conditional gcode is not yet in dsf 1.3.1, correct?
                        • stonewaterundefined
                          stonewater
                          This has been driving me crazy for months - can confirm console output is restored for G32 (and others for me) with with 2.1.1
                          Thank you.
