    Higher current than rated for short time
    • TCundefined
      TC
      Hi all,
      I am constructing a T-lock for my tool charger right now and I want to drive it with an E3D slim stepper motor. It is working fine but the motor tends to skip steps since the torque is only about 13 Ncm. Now I am wondering if it is possible to increase the current of the stepper beyond the rated 1.4 A to reach higher torque. Since the motor is in idle mode for most of the time and only moves when locking or unlocking the tool I was hoping it could take it. Does anyone have experience with this and can estimate how high I can go. And is there any danger for the Duex board to which it is connected?
      Thanks ahead
      TC
      • Danalundefined
        Danal
        I've gone a little past my tool lock stepper. The only thing to be careful: There is only ONE "idle" current factor for all steppers. So if you are thinking about upping lock motor current, and lowering standby %, be aware that you could cause your XYZ motors to not hold at that lowered %.
        Very low risk for the driver.
        And, last thought: I am using a planetary geared stepper, for the reasons you describe, on the lock only. It doesn't (much) matter how fast the lock/unlock occurs. More torque than heat (from current) is a good use for gears.
        TCundefined 1 Reply Last reply Reply Quote 0
        • TCundefined
          TC @Danal
          @Danal Thanks. Yes that is an important point. That is why I planned not to change the idle factor but to increase the motor current just before the motor moves and then to decrease it again. Is that possible?
          Of course a geared stepper would be better but space is a very critical parameter in my setup. That is why I wanted to try it with the slim stepper in the first place.
          Can you estimate how much I can increase the current for about one second? Double it? Is it just a question of heat development or are there other ways the stepper could damage itself?
            I recall reading on the E3D forum that the coupler motor current is increased to 600mA during coupling/uncoupling, and reduced to 400mA afterwards.
            • Danalundefined
              Danal
              @TC said in Higher current than rated for short time:
              Yes, entirely possible. Duet configuration commands are fully dynamic.
              AFAIK, heat only. Infrared it while doing a long sequence of tool changes. Look up for your individual motor, but generally they can get pretty hot with no damage.
              • TCundefined
                TC @Danal
                @Danal thanks a lot
