    Bed mesh generation
    • rhoiasundefined
      rhoias
      HI,
      After following the guide and setting my offsets, when running G29 the probing starts at X5 and Y3. In config.g i have defined M557 X50:300 and Y15:285. My Probe is on the left of the nozzle so when the mesh starts at X5 and Y3 the probe is outside the bed area. Im using an NPN cap sensor btw.
      Here is my config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Fri Dec 27 2019 23:39:02 GMT+0100 (sentraleuropeisk normaltid)
      G90                                      ; send absolute coordinates...
      M83                                      ; ...but relative extruder moves
      M550 P"CR-10"                            ; set printer name
      M551 P"********"                         ; set password
      M552 S1                                  ; enable network
      M586 P0 S1                               ; enable HTTP
      M586 P1 S0                               ; disable FTP
      M586 P2 S0                               ; disable Telnet
      M569 P0 S1                               ; physical drive 0 goes forwards
      M569 P1 S1                               ; physical drive 1 goes forwards
      M569 P2 S0                               ; physical drive 2 goes forwards
      M569 P3 S1                               ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                         ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                  ; configure microstepping with interpolation
      M92 X80 Y80 Z400.00 E101.00         	 ; set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00      ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00  ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                  ; Set idle timeout
      M208 X0 Y0 Z0 S1                         ; set axis minima
      M208 X300 Y300 Z400 S0                   ; set axis maxima
      M574 X1 Y1 S0                            ; set active low and disabled endstops
      M574 Z1 S1                               ; set active high endstops
      M558 P5 H5 F120 T6000                    ; set Z probe type to modulated and the dive height + speeds
      G31 P500 X45 Y12 Z1.57                    ; set Z probe trigger value, offset and trigger height
      M557 X50:300 Y15:285 S20                  ; define mesh grid
      M307 H0 B0 S1.00                         ; disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R4700              ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                             ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700              ; set thermistor + ADC parameters for heater 1
      M143 H1 S300                             ; set temperature limit for heater 1 to 300C
      M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                         ; define tool 0
      G10 P0 X0 Y0 Z0                          ; set tool 0 axis offsets
      G10 P0 R0 S0                             ; set initial tool 0 active and standby temperatures to 0C
        jay_s_uk
        Is your probe to the left or right of your nozzle?
        Assuming its on the left and to the right is +x you need to change your nozzle offset from +45 to -45.
        Same goes for the Y offset of your probe too
        • tobias_munichundefined
          tobias_munich
          if your probe is on the left, shouldn't the X-offset be negative?
          Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
          Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
          Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
          • rhoiasundefined
            rhoias
            You are absolutely right! Thank you! Don't know how i missed that...
