    G1 H1 Z-255 doesn't seem to work
    • jovundefined
      jov
      The homing of the Z axis with the command G1 H1 Z-255 F360 doesn't seem to work. This is my homeall.g:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 21:33:03 GMT+0100 (Central European Standard Time)
      G1 H2 Z5 F6000          ; lift Z relative to current position
      G1 H1 X-290 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-290             ; home X axis
      G1 H1 Y-305             ; home Y axis
      G1 X5 Y5 F6000          ; go back a few mm
      G1 H1 X-290 F360        ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-305             ; then move slowly to Y axis endstop
      G1 H1 Z-255 F360        ; move Z down stopping at the endstop
      G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
      Every other command in the homeall.g works if I enter them in the console window, except that one. If I replace the last three lines with:
      G30
      G90
      G92 Z5
      I get the proper homing behaviour.
      But I don't understand why G1 H1 Z-255 doesn't work, am I missing something here?
      • SIamundefined
        SIam
        your z-min is on 0 so you can't drive in to negative area
        G92 Z0
        btw why you have so big negative settings?
        i have overseen that you use the relative positioning...
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          Are you using a probe or an endstop switch?
          G30 is for the probe, so if that works, you must be using a probe.
          G1 H1 Z-255 will only work if you have an endstop configured and installed for Zmin.
          • jovundefined
            jov
            @Phaedrux said in G1 H1 Z-255 doesn't seem to work:
            Aaaaaah, thanks. I'm using a probe indeed (Piezo Orion).
            • Danalundefined
              Danal
              H2 will work with a probe. Maybe.
