    Bad case of noobism HELP!!
    • my67nova
      my67nova last edited by
      Trying to setup multiple point for mesh bed leveling and I errors from something like not clockwise direction to the latest G32
      Bed calibration error: 2 points provided but only 3, 4 and 5 supported. here is where I am at now. I tried changing the T values to numerical order ect. nothing works yet. I don't think my forehead can take much more pounding on the desk! Here is my BED.G file;
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool on Wed May 03 2017 10:36:50 GMT-0400 (Eastern Daylight Time)
      ; Clear any bed transform
      M561
      ; Probe the bed at 17 points
      G30 P0 X20 Y20 H0 Z-99999
      G30 P0 X20 Y70 H0 Z-99999
      G30 P0 X20 Y110 H0 Z-99999
      G30 P0 X20 Y180 H0 Z-99999
      G30 P0 X70 Y180 H0 Z-99999
      G30 P0 X120 Y180 H0 Z-99999
      G30 P0 X180 Y180 H0 Z-99999
      G30 P0 X180 Y110 H0 Z-99999
      G30 P0 X180 Y70 H0 Z-99999
      G30 P0 X180 Y20 H0 Z-99999
      G30 P1 X120 Y20 H0 Z-99999
      G30 P1 X70 Y20 H0 Z-99999
      G30 P1 X70 Y70 H0 Z-99999
      G30 P1 X70 Y110 H0 Z-99999
      G30 P1 X120 Y110 H0 Z-99999
      G30 P1 X120 Y70 H0 Z-99999
      G30 P4 X100 Y100 H0 Z-99999 S
      • T3P3Tony
        You are better off using mesh bed leveling:
        https://duet3d.com/wiki/Using_mesh_bed_compensation
        Use M557 to define the grid and then G29 to probe it.
        www.duet3d.com
        • my67nova
          Tried doing that would not save to the bed.g file or does it need to? I deleted and remade the folder then ran it again then M500 still not saving I must be missing something…...or not?
            When you run G29 S0 or just G29, it will either fail and report an error on the Gcode Console, or succeed and create the heightmap.csv file in /sys on the SD card. You can see what is in the file by going to Settings->System Editor in the web interface, or view it graphically.
            • Tinroof866
              Tinroof866 last edited by
              Im curious how to view the height map graphically. I have the heightmap.cvs.
              Thanks
                Assuming you are using DuetWebControl 1.15a or 1.15b, right click on the arrow next to the Auto Bed Compensation or Auto Delta Calibration button on the Control page, then you get a drop-down menu that includes an option for viewing the height map.
                • Tinroof866
                  Thanks, I didnt have the newest WebControl.
