    Modix Big120X Upgrade
    • iff7378undefined
      iff7378
      I've got one of these gigantic printers with a RAMPS controller. I'm considering upgrading the whole control system to the Duet 3. Modix just released a version 3 of their printer with a Duet 2 but I figured why not go right to the Duet 3. The whole reason for this is to be able to use the magnetic filament monitors. Its no fun when a 24 hour print fails in the last hours because the filament jammed.
      I want to make sure all of this will work before I order a ton of stuff.
      With the Duet 3 and a raspberry Pi, I would just run a touchscreen off the Pi's HDMI port and not use a PanelDue right?
      Right now I think the setup is:
      Duet3:
      X Y Z Steppers
      Output to heated bed SSR
      Bed temp sensor
      CAN bus to Tool Distribution to two toolboards
      Toolboard 1 has:
      • Extruder Stepper 1
      • Heater 1
      • Fan 1
      • Filament Monitor 1
      • BLTouch
      • Nozzle Blower Fan
      Toolboard 2 has:
      • Extruder Stepper 2
      • Heater 2
      • Fan 2
      • Filament Monitor 2
      Any feedback on the setup would be appreciated!
        That all sounds good, except that the firmware support for filament monitors connected to tool boards or Duet 3 expansion boards isn't written yet. It's planned for the RRF 3.02 release.
        • iff7378undefined
          iff7378
          Awesome thanks! Any idea when that release is planned to happen?
          Edit: Is it possible to directly connect the monitors to the Duet 3 mainboard with the current firmware?
            dc42 administrators @iff7378
            @iff7378 said in Modix Big120X Upgrade:
            Release 3.01 should be out by the end of this month. 3.02 will most likely arrive late March or late April.
            Yes.
