    Correction for g code documentation
    218
    • jens55undefined
      jens55
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M117_Display_Message
      The documentation reads :
      M117: Display Message
      Example
      M117 Hello World
      according to what I gather, it SHOULD read M117 "Hello World"
      (quotation marks are currently missing)
        dc42 administrators @jens55
        The quotation marks are optional. I have updated the documentation.
        • jens55undefined
          jens55
          Thanks .... but with RRF3.0 and without the quotation marks, there was no output to the web interface. Once the quotation marks were used, the output was there.
          I guess I should mention that this was happening as I was trouble shooting my weird issue with gcode that hung (see other thread) so I suppose this could have affected things.
            @jens55 said in Correction for g code documentation:
            Which Duet are you using; and if it is Duet 3, is it with or without the SBC?
            • jens55undefined
              jens55
              Duet2 wifi
              jens55undefined 1 Reply Last reply Reply Quote 0
              • jens55undefined
                jens55 @jens55
                Just tried it out without quotation marks and it does work fine so all I can say is that it could all boil down to some weird file corruption issue as reported here:
                https://forum.duet3d.com/topic/14541/weird-fault-on-homey-g
                I tried many different things in an attempt to isolate the issue and it is quite possible that I got my wires crossed between the quotation marks and the homey.g file locking up and what not.
                In any case, I thing it's great that you changed the documentation for completeness sake - thanks
                • Danalundefined
                  Danal
                  Some early releases of DSF on Duet 3 + Pi did very odd things without the quotes. IIRC, there was some internal string escaping (or un-escaping) going on.
                    dc42 administrators @Danal
                    The rule is:
                    • Where a string parameter is used with a letter to introduce it, quotation marks should be used around the string. For RRF3 on Duet 3 with attached SBC, the quotation marks are mandatory. In other cases they are optional for some older commands, e.g. M98.
                    • Where a string parameter used without a letter to introduce it, quotation marks are optional. Examples are M32 and M117.
