    resume.g not executed
    • Furbyhaxxundefined
      Furbyhaxx
      If i pause the print (over DWC or PanelDue) and restart the file resume.g is not executed.
      What can cause this?
      Board: Duet WiFi 1.02 or later + DueX2
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
      Version von Duet WiFi Server: 1.23
      • appjawsundefined
        appjaws
        Which firmware are you using?
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
        • Danalundefined
          Danal
          Check basics first:
          • Must be in /sys
          • Must be named exactly "resume.g"
          • Try putting an M117 "this is resume.g" in the file, to see if it really is/isn't being executed.
          • Is pause.g being executed?
          • How are you resuming? DWC?
