G54-59 not working in start.g?
For debugging, add G10 L2 with no other arguments. This will print offsets for the current work system on the console.
This can also be the second command on a line, so this is a good way to do this for debugging:
G55 G10 L2
@Danal said in G54-59 not working in start.g?:
G55 G10 L2
I tested it. It displays the correct offsets of system 2 even if it is executed from start.g. still the next G1 command goes to the wrong place...
@TC said in G54-59 not working in start.g?:
G55 G10 L2
Wow, that's really not good.
What releases are you running? Check the "machine specific" tab in the web interface, and copy the three lines that look like this (you may or may not have a DSF line):
Board: Duet 3 MB6HC (MB6HC)
DSF Version: 1.2.4.0
Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-RC2 (2020-02-18b1) -
Board: Duet WiFi 1.02 or later + DueX5
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC1 (2020-02-08b3)
Duet WiFi Server Version: 1.23 -
But the problem allready existed before the upgrade to RRF3
Duet WiFi Server Version: 1.23Hmmm... you could try RC2, just for completeness. It uploads just fine via web "system" tab.
https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC2
Ahhh... interesting. I'm really stumped as to what would cause this, it would seem this is a function of a very basic parser that should work for you and me both.
Hmmm... @dc42 will probably need to look at this one.
Commands in macro files in the /sys folder always ignore workplace offsets. This is so that movement commands in homing files, pause.g and so on always go to the same places regardless of what coordinate system you are in.
Ah ok. In my case I set the origin and therefor the place to print before each print job. That is important because I need to print on prepared objects. Is it possible to add the function that if there is a G55 command directly in front of a G1 command it applies the offset?
Or is it possible to get the offsets of the coordinate systems from the object model?
Ah looks like I found it
Thanks to your awsome object model it was easy to solve!
@dc42 said in G54-59 not working in start.g?:
Very interesting and good to know. THANKS!
