Heater fault after upgrade to RC2
  • Hi all,
    I am facing a weird phenomena. After I upgraded the new firmware version, I tried to heat up my tools 0 and 1 and both showed a heater fault:
    Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C
    The temperature is rising normal until the error appears. The bed heater does not show this error.
  • I just tried the internal build dc42 recomanded in the RRF 3.01 RC2 thread and it solved the problem 😉
    Will let this topic online in case someone else has the same issue.
