Solved Bed heater temp is not working after switch to RRF config 3.0
Hi!
I have now found out that i had been running on firmware 3 configuring it with a file created with the version 2 configurator.
It is something that should not be possible to happen when at my age and so many years with computers and electronics but it did......
However i have now have improved myself by running the right version of the configurator.
But immediatly something is not right, the temperature of the bed is -273.1 degrees , filament heater is ok with 20.6 degrees. If i swap the termistor connectors there is no change. I had this working previously though.
I have a sparkcube v1.1 XL
It's a corexy with three zaxis motors
Any idea's of what this is?
regards
/Sten
config.g -
Your config looks good. I assume this is a Duet 2?
Is bed thermistor plugged in here:
Yes, it's plugged in there now and it's working, sorry for the loss of your time
