Attempting to extrude with no tool selected
  • I have checked other similar posts but no luck. I cannot get the extruder to respond. It tried it from the web interface and the PaneDue yet the same error keeps popping up when I try an extrude or retract command. This is my code:
    M563 P0 S"MYTHprint" D0 H1 F0 ; define tool 0
    Can someone point me in the right direction?
  • did you have this in the near of the end in your config.g ?
    T0                                                  ; select first tool
  • @SIam This is at the end, the last entry.
    From the console, send T with no parameters to see whether it reports that tool 0 is selected. Alternatively, check whether Duet Web Control shows Tool 0 as active.
  • @dc42 Sending T on the console returned an error that no tool is selected. On the Duet Web Control I clicked on "Tool 0" and made it active. Now it works on both the PanelDue and the Web Control. Interesting Thanks for the assist.
