RRF 3.0 upgrade leads to 2000c
  • Good day, I just moved to RRF 3.0 from 2.07 and use the config tool to set everything up. But now my hotend and bed are reading at 2000C. no hardware was changed between 2.07 and 3.0. It was printing up until I pushed the new file. hotend is a E3D and bed is a makerbot heated bed from a 2X.
    Config start:
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Feb 29 2020 22:08:20 GMT-0700 (Mountain Standard Time)
    M550 P"My Printer" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X88.00 Y88.00 Z400.00 E2700.00 ; set steps per mm
    M566 X3000.00 Y3000.00 Z12.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1800.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
    M906 X850 Y800 Z400 E550 I10 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-70 Y-127 Z0 S1 ; set axis minima
    M208 X70 Y127 Z155 S0 ; set axis maxima
    M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
    M574 Y2 S0 P"ystop" ; configure active-low endstop for high end on Y via pin ystop
    M574 Z1 S0 P"zstop" ; configure active-low endstop for low end on Z via pin zstop
    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
    M558 P9 C"zprobe.in+zprobe.mod" H3 F240 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y-19 Z3.5 ; set Z probe trigger value, offset and trigger height
    M557 X-55:55 Y-112:112 S50 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0 ; create bed heater output on !bedheat and map it to sensor 0
    M143 H0 S100 ; set temperature limit for heater 0 to 100C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1 ; create nozzle heater output on !e0heat and map it to sensor 1
    M106 P0 C"Part fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
    M106 P1 C"Hotend fan" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
    M106 P2 C"Leds" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
  • Moderator
    Please send M115 and check your installed firmware version.
    Your BLTouch won't work with your current M559 command. Change the C parameter to C"^zprobe.in".
  • @Phaedrux
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
    What M559 are you referring to. I don't see it listed. Are you referring to the M558? and if so do i want to change it to M559?
  • Moderator
    @Hitbox said in RRF 3.0 upgrade leads to 2000c:
    M115
    You've not actually updated the firmware to version 3.
  • Ok which firmware version should be listed? as there seem to be three different Duet3firmware listed in the 3.01 RC3 release?
  • Moderator
    Try 3.0 to start with. You'll need that release first before you can upgrade to the other later versions.
  • Ah there we go. Thank you the temps now are reading nominal. though the push to RC3 seems to be stuck? but i think i found some forum post to get that to work.
