    homeall.g works w/stall detection but g28 belt slips w/slicer
    • supernovaeundefined
      supernovae
      I noticed in firmware 3 on duet wifi that if I do a G28 in my gcode start (inside slicer), stall detection doesn't work well and my belts slip as print head rams homing to X 0. If I run homeall.g everything works fine and is less violent.
      So I updated the start gcode with setting motors to 50% power (which is what I do in homeall) and the G28 there is fine - not ramming or belt slipping.
      It didn't use to do this, but I can't isolate when it started... /shrug heh
        Would need to see your files to be able to see what's happening.
