    Selecting a G-Code editor
    214
    • Jim46
      Jim46 last edited by dc42
      Hello All,
      I'm just now starting to assemble my Duet3D 6HC (5 Stepper NEMA23 Hi Torque), RasberryPI4, 7"screen and am curious. I received this article today called 10 Best G-Code editors...
      https://all3dp.com/2/best-g-code-editors-online-offline/?utm_source=push
      So, what do you all recommend? This is my first exposure to G-Code.
      Thanks in advance,
      J
      • Jim46
        Sorry, wrong title. that issue was fixed.
        • Jim46
          Should read... selecting a G-Code editor...
          • A Former User
            A Former User last edited by
            just edit it
            Jim46 1 Reply Last reply Reply Quote 0
            • deckingman
              deckingman last edited by deckingman
              In answer your question, (rather than the title), a gcode file is just a text file so whatever text editor you feel comfortable with. Bit it might depend on what exactly it is that you want to do. Is it just minor tweaks to the start and end code or something else? For simple things my personal preference is notepad++ (it's free). For my complex things like for example changing the mixing ratio every three layers, I write little python scripts and run those on the file.
              • nhof
                nhof last edited by
                I agree with Ian that text editors are the way to go for minor edits. Notepad++ chokes up for me on files past 100,000 lines, so I switched over to VS Code with a g-code plugin for highlighting. Works flawlessly even with 1,000,000+ line files.
                • OwenD
                  OwenD last edited by
                  RJ Texted now has a syntax file available I did that contains the RRF object model and GCode references.
                  You have to manually enable it.
                  Please note, that at present the file is only contained in the "Update" download, so even if you download V14.4, you also need to install the update them go into the background and enable it
                  as per this thread
                  • Jim46
                    Thank you all for your comments about he G_Code Editor. Very Helpful!
                    • Jim46
                      Jim46 @Guest last edited by
                      @bearer
                      Hi Deckingman,, Liked your wordpress link.
                      • Danal
                        Danal last edited by
                        Just a slight pitch for Sublime Text. It does cost money though...
