    Solved Duet 3 MB 6HC main board firmware help
    Firmware installation
    208
    • TouristMK4
      TouristMK4 last edited by
      I decided to try something new and got a new Duet 3 MB 6H board.
      In my attempt to get to know the board I deleted the current firmware per instructions https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3. Now I am not able to connect my board through any user interface.
      Instructions I followed;
      • Erase current firmware with jumper
      • Load/write [Duet3Firmware_MB6HC.bin] through Bossa
      I have also tried loading/write; Duet3_SDiap_MB6HC.bin, RepRapFirmware.bin with no success.
      I know I am missing something really simple but I been at it with no success. I would appreciate any help getting me started past this point as the rest will be more intuitive.
      Thanks,
      • droftarts
        droftarts administrators @TouristMK4 last edited by
        @TouristMK4 your BOSSA screenshot looks correct. Did you remove the erase jumper from the board? What happens when you press Write?
        • TouristMK4
          TouristMK4 last edited by TouristMK4
          Yes, I removed the jumper once the port was detected by Bossa. It successfully writes, verifies, and reads.
          After I close the Bossa app and start YAT. See image for the terminal setting, it seems like it is picking up the bossa program port.
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @TouristMK4 last edited by
            @TouristMK4 said in Duet 3 MB 6HC main board firmware help:
            If you hit the windows key + x and choose device manager, you can expand the tree where it shows Ports (Com & LPT) and it should show you the name of the driver in use. Bossa and RRF have different names. Ought rule out any uncertainty.
            • TouristMK4
              It shows as Bossa. I am now having an issue where my computer pics up the port but when I write the .bin through Bossa and restart the control board, my computer no longer detects the port. It only picks it up when I erase through the jumper. 10.PNG
              • A Former User
                A Former User last edited by
                You're using the Duet3 as a standalone board? Does removing the SD card make a difference?
                  dc42 administrators @TouristMK4 last edited by
                  Please try the following:
                  • Download a fresh copy of the 3.01-RC3 Duet3Firmware_MB6HC.bin firmware
                  • Erase the firmware again, then remove the jumper (you must do this before issuing the Write command in Bossa)
                  • Check the 3 boxes as required and click Write in Bossa
                  • Click Verify in Bossa and check that no errors are reported
                  • Reboot the Duet. Watch the red Diag LED. It should flash on/off slowly and steadily. If it gives a number of flashes and then stops, then repeats, count the number of flashes and report it here.
                  • TouristMK4
                    It works.
                    The issue was the copy I initially downloaded, it might have been corrupted. Everything looked good [write, verify] up to the reset point, the board stopped communicating.
                    Thank you
