    Duet Web Control homing buttons
    • Weevil
      Weevil last edited by
      The buttons for Home X and Home Y work. But the Home Z button doesn't deploy the BLTouch. I have to run the g code file for homez or homeall to get the BLTouch deployed. I am using Web controller version 2.0.7
        The button just runs homez.g
        What do you have in homez.g?
        To use the BLTouch there should be a G30 command to probe the bed. Perhaps you have a G1 H1 move instead?
        Weevil 2 Replies Last reply Reply Quote 0
        • Weevil
          Weevil @Phaedrux last edited by
          @Phaedrux This is what I have for homez.g:
          ; Home Z Axis for BLTouch
          G90 G1 X150 Y150 F10000 ; Move to the center of the bed
          M558 F500 ; Set the probing speed
          G30
          M558 F50 ; Set a slower probing speed
          G30
          It works perfectly when I run it directly. It's the Home Z button on the Web Controller that is not deploying the probe.
          • Weevil
            @Phaedrux Problem solved. From being an insufferable newbie, I realized my system files were in the wrong place. Thanks for the assist.
              Phaedrux Moderator @Weevil last edited by
              @Weevil said in Duet Web Control homing buttons:
              It happens.
