    Share your DueUI configuration!
    DueUI
    • gtj0
      gtj0 last edited by
      If you have a DueUI configuration that you'd like to share, this is the place! Add a reply with a screenshot or two and attach your config file.
      Let's keep this topic to config announcements and updates only. If you need help with a config that was shared here, please create a new topic and mention the creator.
      kgolger 1 Reply Last reply Reply Quote 1
      • stuartofmt
        stuartofmt last edited by stuartofmt
        Note that this version was created for Dueui 3.0.2. Because of a change in the way DWC and hence Dueui now report the object model - this version is not compatible with later versions of Dueui.
        I have an Ender 5 with Duet2 Wifi. I have a Raspberry Pi with 7" TFT mounted on the Printer.
        I used it to serve up a camera and provide some local control with DWS in the browser on the Pi.
        This was a fairly clumsy approach because of the small screen and the lack of touch precision. So I decided to give Dueui a go.
        I was after a minimal set of control for the occasions when I was standing, mesmerized, in front of the printer.
        DWS on my laptop is, of course, used for more complete control.
        Other considerations included:
        The Screen I am using is only 800 x 600 pixels.
        I did not want to have to scroll up/down or left/right.
        The browser (chromium) is used in full screen mode.
        Attached is the first version of my configuration.json together with some macro's that I use.
        *EDIT - A better version is posted as V3. I have removed the prior versions. *
        To get everything working - I had to modify two of the javascript files supplied by @gtj0 who will update those files in due course - I am including the modified dueui.js and dueui_widget.js files as well
        I am very happy with the results so far and look forward to improving as I go.
        I will explain a little about each of the panes below.
        General
        The theme I chose is "Darkly" - other themes may affect the layout.
        I trimmed the menu bar at the top to make it fit better.
        I placed the log / status just above the menu tabs.
        Most everything else fits in between.
        In V3 - I added output for M117 Messages (not shown in the screen shots) because I liberally sprinkle messages in my macros and gcode.
        Printer
        This is a really just intended for basic monitoring, stop / start etc.
        Because I like to see Nozzle and Bed Temperature that is included.
        Babysteps are small i.e. assumed the printer is more-or-less calibrated.
        Calibration
        The intent here is to provide simple calibration control and monitoring.
        I use a Z-Probe (BLTouch) so bed calibration is automagic. The "Calibrate" button calls a macro () that does all the work.
        Since I often change hotends - the Z axis offset can change so I have included a capability to measure the offset.
        The "Z Adjust Start" button calls a macro () to setup for adjustment using one of the standard techniques.
        It first homes all - so after that has happened you can go ahead and adjust the nozzle to the bed to "paper thickness".
        When done - pressing the "Done" button performs a single probe (and another home all just because).
        The Z offset is reported in the log / status bar and can then be used to adjust your G31 settings.
        Heightmap
        No changes here - just copied from the sample config file.
        Control
        Edit - Made some changes so as not to need keyboard and posted as V2. Removed the need for a keyboard
        I mainly use this for filament changes and such. Heat up the nozzle etc.
        I personally do not use standby and such. In any case, wanted to "unclutter' the UI for this screen.
        The config file comments out a second row of nozzle temps and Fan 0 these can be added back in easily if you want.
        There is also a control to reposition the bed (Z axis) to specific positions (useful for getting access to the bed).
        Console
        More or less the same as the sample config file.
        NOTE THE FILENAMES GET CHANGED DURING DOWNLOAD SO YOU WILL NEED TO RENAME THEM BACK TO THE ORIGINAL
        Config File
        config_pi_panel_sofmt_V3.json
        Remove the .txt from these two files before using
        dueui.js.txt
        dueui_widget.js.txt
        Macros
        AutoProbeCalibration.g
        Z-AdjustStart.g
        Z-AdjustStop.g
        • kgolger
          kgolger @gtj0 last edited by kgolger
          @gtj0; @all:
          I would like to publish my setting here. It is a first, briefly tested version. Menu language is mainly german, but can be easily changed in dueui_config_default.json.
          Here some screenshots:
          Hardware:
          Duet2 Wifi, FW3.3, DWC V3.4, DueUI V3.3.1
          Pi4 B, Raspbian GNU/Linux 10 (buster), Kernel: 5.10.60-v7l+
          firefox: Mozilla Firefox 78.14.0esr
          Firefox initialization at Pi startup:
          @firefox-esr --private-window --kiosk http://192.168.x.xxx/dueui.html?dueui_config_url=dueui_config_default.json
          Touchscreen settings for Waveshare H 7" in /boot/config.txt:
          hdmi_group=2
          hdmi_mode=1
          hdmi_mode=87
          hdmi_cvt 1280 1024 60 6 0 0 0
          DueUI Data (Dueui.html, dueui-bundle.js, dueui_config_default.json and my DWC data.g collection):
          Download link: www.kgolger.at/DueUI/V3.3.1/DueUI_V3.3.1_kgolger_settings.zip
          Suggestions for changes and improvements are welcome. I am a professional mechanic, not a programmer. for this reason I can not answer questions that go deeper into the system (Java, C++ ....).
          Have fun testing and best regards,
          Karl
          • kgolger
            kgolger last edited by kgolger
            actual version (download configs and pictures): http://www.kgolger.at/DueUI/V3.3.1.21/DueUI_V3.3.1.21_kgolger.zip
