Main Board for Ultimaker 2+
I would like to update my Ultimaker 2+ with the Duet main board, and I need some help!
Am I right if I take the Duet 2 WiFi or is better the Duet 3?
I also need 1 PT100 Daughter Board, right?
Is it possible to find a firmware configuration for the ultimaker2 +?Thanks for your help.
Hi
i have an UM2+ whit Duet2Wifi and yes if you want to keep the stock hotend as I did then you need the PT100 daughterboard. But if you gonna use a E3D V6 and its sensors then you won't need the daughter board.
Hope this helped a bit
if you upgrade to a duet2wifi then I can share my config file.
@AndreasAdolfsson Consider adding your config set here as well: https://github.com/Duet3D/RRF-machine-config-files
Thanks for all your help!
I took duet 3, I would like to do a gui on the raspberry. If I get a good result I will share it. Thank you.
@Phaedrux I'm trying but don't undertand tried to creat a file but nothing happens
@AndreasAdolfsson Perhaps upload them here then. Github does have a bit of a learning curve. The idea is that you create your own github repository under your own name with your files, and then you submit them to the RRF machine config repository with a pull request. Does that make sense?
@Phaedrux Yes I did a pull request last night
This post is deleted!
@AndreasAdolfsson Would you happen to have or know of a tutorial on how to install duetwifi on my UM2+?
Thanks!
