    Dual Z with single endstop
    • craigrezac7
      craigrezac7 last edited by
      I used to have this setup working correctly. It started out as an Ender 5. I have each motor connected to the board (not in parallel). Everything homes just fine but when I start the print, the stepper on the opposite side of the limit switch keeps trying to raise the bed up. Is there a way for them to stop together? I don't know how I had it working so well before.
      • SIam
        SIam last edited by
        can you post your config.g
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        craigrezac7 1 Reply Last reply Reply Quote 0
        • craigrezac7
          craigrezac7 @SIam last edited by
          @SIam Good call, sorry, I forgot about doing the obvious lol
          M550 P"Ender 5" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes forwards
          M569 P1 S0 ; physical drive 1 goes forwards
          M569 P2 S0 ; physical drive 2 goes forwards
          M569 P3 S0 ; physical drive 3 goes forwards
          M92 X80.00 Y80.00 Z400.00 E830.00 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X230 Y230 Z300 S0 ; set axis maxima
          M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin !zstop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:215 Y15:215 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4100 ; configure sensor 0 as thermistor on pin bedtemp
          M143 H0 S175 ; set temperature limit for heater 0 to 175C
          M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S450 ; set temperature limit for heater 1 to 450C
          • SIam
            SIam last edited by SIam
            You have for each axis only one stepper configured see m584 for the z axis which you have 2 steppers you must add this stepper to m584 m350 and m569
            • craigrezac7
              @SIam ohhh ok, I was thinking I didn't have to for some reason with that one. I will look up how to do that again, thank you!
