    M7/M9/M10/M11 Implementation (Coolant and Vacuum) [CNC]
    Firmware wishlist
    cnc mode vacuum coolant cooling
    1.0k
    • webdes03undefined
      webdes03
      It'd be fantastic to see M7/9 for Coolant and M10/11 for Vacuum implemented, even if they simply executed a macro, simply so that the native output from a post processor could control vacuum and coolant.
      • T3P3Tonyundefined
        T3P3Tony administrators @webdes03
        @N131MG you can create a macro called M7.g or M9.g(etc) in the /sys/ directory and that should be run when that gcode is sent.
        From here: https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
        If you try to use a G- or M-code that the firmware doesn't recognise, it will try to run a macro file of that name. For example, command M650 tries to run /sys/M650.g.
        We should certainly document that feature better.
        www.duet3d.com
        webdes03undefined 1 Reply Last reply Reply Quote 3
        • webdes03undefined
          webdes03 @T3P3Tony
          @T3P3Tony Whaaaaaat! I guess we can close this request then 🙂
          • T3P3Tonyundefined
            @N131MG please try it and confirm it works as you expected.
            www.duet3d.com
            webdes03undefined 1 Reply Last reply Reply Quote 1
            • T3P3Tonyundefined
              @N131MG p.s. updated my first reply as I realise it M7.g or M9.g and not M79.g!
              www.duet3d.com
              • webdes03undefined
                webdes03 @T3P3Tony
                @T3P3Tony Works exactly as you described, thanks!
                • PCRundefined PCR referenced this topic
