    Pressure Advance with S2.0 ??
    • LichtiMC
      LichtiMC last edited by
      I have a bowden extruder with the tube about 400mm long.
      So it's suggested to use M572 D0 S0.1 as pressure advance value.
      I did the testprint as instructed on the wiki pake about pressure advance and did'nt get a result when playing with values from 0.1 - 1.
      Then just for fun I tried to use 2.0 and got a beautiful finished z-seam.
      Of course the printer is extremely slow as it's written in the wiki.
      Does anybody have a clue what's going on here? Is there another incorrectly set option that could cause this situation to occur?
      Thank you very much!
      bot 1 Reply Last reply Reply Quote 0
      • bot
        bot @LichtiMC last edited by
        @LichtiMC
        The slowness is due to your extruder jerk limit. For PA to work, the extruder needs to instantly jump ahead. If it's limited by the jerk to an amount lower than it wants to due to the PA adjustment, then it will slow down the acceleration of the X/Y axes to accomodate the lower jerk limit. IE, it forces the toolpath/PA combo to not require more E jerk than is set in M566.
        *not actually a robot
        • LichtiMC
          Thank you for your answer.
          So you think a pa-value of S2.0 is normal even though the instructions imply that it should work with 0.1 for my tube length?
          I have an CoreXY Printer and following e-jerk values activated: M566 X900.00 Y900.00 Z12.00 E120.00
          How would I have to adjust the values to get more "normal" speeds?
            dc42 administrators @LichtiMC last edited by
            @LichtiMC said in Pressure Advance with S2.0 ??:
            I suspect the optimum for that tube length is longer than that, perhaps 0.2 or 0.3.
            Increase that E parameter. I use 600 on my delta with Bondtech extruder and 600mm Bowden tube. I could probably use a higher value.
              Have you seen this yet? https://duet3d.dozuki.com/Wiki/Pressure_advance?revisionid=HEAD#Section_How_much_pressure_advance_to_use
              • LichtiMC
                LichtiMC last edited by LichtiMC
                Thank you for your answers. I will definitely try the suggestions and reply, but for now I have to solve another issue first:
                https://forum.duet3d.com/topic/14954/volumetric-extrusion-massive-overextrusion
