    Volumetric extrusion = massive overextrusion!
    • LichtiMCundefined
      LichtiMC
      I have a CoreXY-Printer with duet ethernet and use volumetric extrusion because with Cura and g-code flavor setting "marlin (volumetric)" I can use the firmware retraction feature of RRF (3.01-RC3).
      But even though I configured...
      M200 D1.75 ; set all extruder filament diameters to 1.75mm
      ... I get an overextrusion of more than 2 times the wall thickness setting (0.4 - actual thickness: about 1mm)
      My e-steps are configured correctly and now I don't know anymore where to look for the error.
      Here my duet config.g:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Mar 14 2020 22:42:45 GMT+0100 (Mitteleuropäische Normalzeit)
      M111 S1                                                ; Debugging on/off 0/1
      G21                                                    ; Work in millimetres
      G90                                                    ; send absolute coordinates...
      ;M83                                                   ; ...but relative extruder moves, oder? NO: https://duet3d.com/forum/thread.php?id=1190, https://betrue3d.dk/category/duet-wifi/page/2/
      M550 P"Davids Ender-4"                                 ; set printer name
      M667 S1                                                ; select CoreXY mode
      M552 P0.0.0.0 S1                                       ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                             ; enable HTTP
      M586 P1 S0                                             ; disable FTP
      M586 P2 S0                                             ; disable Telnet
      M569 P0 S1                                             ; physical drive 0 goes backwards
      M569 P1 S1                                             ; physical drive 1 goes backwards
      M569 P2 S0                                             ; physical drive 2 goes forwards
      M569 P3 S0                                             ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                       ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
      M92 X80.24 Y80.24 Z400.00 E96.295                      ; set steps per mm
      M566 X900.00 Y900.00 Z20.00 E600.00                    ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z480.00 E1200.00              ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z100.00 E250.00                 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z500 E800 I50                           ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                ; Set idle timeout
      M208 X-4 Y-7 Z0 S1                                     ; set axis minima
      M208 X215 Y215 Z300 S0                                 ; set axis maxima
      M574 X1 S1 P"!xstop"                                   ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                    ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                                     ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H2 F120 T7200                                  ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:200 Y15:175 S20                                ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092         ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S285                                           ; set temperature limit for heater 1 to 285C
      M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"Part-Fan" S0 H-1                             ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"Hotend-Fan" S1 H1 T45                        ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                                   ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H1 T45                                      ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                       ; define tool 0
      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings:
      M572 D0 S0.3
      T0                                                     ; select first tool
      And here my Cura "Start G-code":
      G21 ; metric values, G-code flavor Marlin (Volumetric) for Firmware Retraction...
      G90 ; absolute positioning
      M82 ; set extruder to absolute mode
      G28 ; home all axes
      G1 X0 Y10 Z0.5 F3000 ; get ready to prime
      G92 E0 ; reset extrusion distance
      G1 X160 E20 F600 ; prime nozzle
      May anyone can guide me to a solution for this problem.
      Thank you.
        There's no reason you can't use firmware retraction when selecting reprap flavour in Cura. I do.
        LichtiMCundefined 1 Reply Last reply Reply Quote 0
        • botundefined
          bot
          I've never used volumetric extrusion before, but do you have to set the E steps per mm to be in volumetric units?
          *not actually a robot
          • LichtiMCundefined
            LichtiMC @Phaedrux
            @Phaedrux said in Volumetric extrusion = massive overextrusion!:
            I can't find a setting in cura that outputs G10/G11 when g-code-flavour reprap is set. Could you tell me where to set this option?
            @bot said in Volumetric extrusion = massive overextrusion!:
            Can't imagine this is the case...
            • botundefined
              bot
              Yeah, that wouldn't make sense because it would negate the need for the filament diameter setting.
                You'll need the Printer Settings plugin from the Cura plugin marketplace. That will add another menu in the settings bar. That's where you'll find the option for firmware retraction. I should have remembered that earlier. Sorry.
