    Bed leveling micro
    • Shenundefined
      Shen
      I've created a simple bed leveling micro for my printer. This might be useful for some of you before we get the auto bed leveling feature. My z-axis is controlled by two ballscrews on either side of the bed alone the x-axis. My micro levels the bed by leveling two points on the bed on either side of the X axis. If you have 3 steppers controlling the z-axis you need to modify the micro to run alone both x and y axis one after another.
      I'm running 3 iterations of the leveling process in the micro. In each iteration the micro will output the heights of the two points you are trying to level. You'll know the bed is level when they are close to each other. You can run the micro multiple times, it takes 20 seconds each time for me. Here is an example, I intentionally moved one side 3mm higher than the other side.
      [[language]]
      Stopped at height 1.014 mm
      Stopped at height -1.276 mm
      Stopped at height 0.290 mm
      Stopped at height -0.403 mm
      Stopped at height 0.057 mm
      Stopped at height -0.102 mm
      Since the initial difference is large my bed is not level after the first run. Here is the second run, the two points are on the same height after second run:
      [[language]]
      Stopped at height -0.021 mm
      Stopped at height -0.024 mm
      Stopped at height 0.000 mm
      Stopped at height -0.011 mm
      Stopped at height 0.001 mm
      Stopped at height -0.003 mm
      Here is the code, you need to change the position of the the two points, z motor mapping, and possibly the feedrate of the movements :
      [[language]]
      ; Setup
      G91
      G1 Z5 F3600 ; Move the platform down. You might need to change the feedrate
      G90
      G1 X136 Y90 F3600 ; Move to center of bed
      M561 ; Disable bed compensation
      G30
      G92 Z0 ; Set Probe trigger point to 0 to make it easier for comparison, and you don't have to change the micro everything you change your trigger height
      ; Iteration 1
      ; Left Side
      G1 X72 F3600 ; Move to the left point
      G30 S-1 ;  Probe without changing the Z height
      M584 Z8 ; Unmap the left side motor, leave the motor on the opposite site of the point you are probing
      G1 Z0
      M584 Z7:8 Restore Z motor mapping
      ; Right Side
      G1 Z5 F3600
      G1 X200 F3600 ; Move to the right point
      G30 S-1
      M584 Z7  ; Unmap the right side motor, leave the motor on the opposite site of the point you are probing
      G1 Z0
      M584 Z7:8
      ; Iteration 2 and 3 are identical to iteration 1
      ; Iteration 2
      ; Left Side
      G1 Z5 F3600
      G1 X72 F3600
      G30 S-1
      M584 Z8
      G1 Z0
      M584 Z7:8
      ; Right Side
      G1 Z5 F3600
      G1 X200 F3600
      G30 S-1
      M584 Z7
      G1 Z0
      M584 Z7:8
      ; Iteration 3
      ; Left Side
      G1 Z5 F3600
      G1 X72 F3600
      G30 S-1
      M584 Z8
      G1 Z0
      M584 Z7:8
      ; Right Side
      G1 Z5 F3600
      G1 X200 F3600
      G30 S-1
      M584 Z7
      G1 Z0
      M584 Z7:8
      ; Final Probe
      G91
      G1 Z5 F3600
      G90
      G30 ; Probe again since the Z height is changed.
      • T3P3Tonyundefined
        T3P3Tony administrators
        I can't test this as I don't have a cartesian printer with two seperately driven Z motors however the output looks great!
        I am really impressed in general as it shows how much can be done with the macro system. Thanks Shen!
        www.duet3d.com
