    udev + bossa = failure to autorecover?
    115
    • A Former User
      Had another silly idea; if my RPi should detect a BOSSA device plugged in, why not have it automatically flash the board with the appropriate firmware.
      While all the Duets have different usb id's when running the firmware, while in the bootloader they're all the same - fortunately bossac can query the chip and from the chip family we can determine which firmware is correct.
      Bus 001 Device 006: ID 1d50:60ec OpenMoko, Inc. (Ed. Duet 2 Wifi)
      Bus 001 Device 006: ID 1d50:60ed OpenMoko, Inc. (Ed. Duet 2 Maestro)
      Bus 001 Device 004: ID 1d50:60ee OpenMoko, Inc. (Ed. Duet 3)
      Bus 001 Device 008: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader
      So to get the ball rolling we need some udev rules.
      /etc/udev/rules/99-duet.rules
      ACTION=="add", ATTRS{idVendor}=="03eb", ATTRS{idProduct}=="6124", RUN+="/home/pi/duet_bossac.sh"
      and reload sudo udevadm control -R
      /home/pi/duet_bossac.sh contain:
      #!/bin/bash
      #RRF2 files and urls
      D2MF=~/DuetMaestroFirmware.bin
      D2MFURL=https://github.com/dc42/RepRapFirmware/releases/download/2.05.1/DuetMaestroFirmware.bin
      D2CF=~/Duet2CombinedFirmware.bin
      D2CFURL=https://github.com/dc42/RepRapFirmware/releases/download/2.05.1/Duet2CombinedFirmware.bin
      #RRF3 files and urls
      #D2MF=~/DuetMaestroFirmware.bin
      #D2MFURL=https://github.com/dc42/RepRapFirmware/releases/download/3.0/DuetMaestroFirmware.bin
      #D2CF=~/Duet2CombinedFirmware.bin
      #D2CFURL=https://github.com/dc42/RepRapFirmware/releases/download/3.0/Duet2CombinedFirmware.bin
      D3=~/Duet3Firmware_MB6HC.bin
      D3URL=https://github.com/dc42/RepRapFirmware/releases/download/3.0/Duet3Firmware_MB6HC.bin
      verifyversion()
        PORT=$1
        #sleep a little extra if asked to do so with $2
        [ $# -eq 2 ] && /bin/sleep $2
        #init serial
        /bin/stty -F $PORT 57600 raw -echo &&
        #flush serial
        /usr/bin/timeout 1s /bin/echo -e "\n\n" > $PORT
        /usr/bin/timeout 2s /bin/cat $PORT &> /dev/null
        /bin/sleep 1s
        #ask for current version
        /usr/bin/timeout 2s /bin/cat $PORT | head -n1 &
        /usr/bin/timeout 1s /bin/echo M115 > $PORT
        /bin/sleep 1s
      erase()
        PORT=/dev/$(ls $1)
        /bin/echo @Erasing
        /bin/echo Device is: $PORT
        /bin/echo Board is:  $(cat $1/../../manufacturer): $(cat $1/../../product) $(cat $1/../../version) \(USB $( cat $1/../../idVendor):$( cat $1/../../idProduct)\)
        verifyversion $PORT
        #send duet to bootloader
        /usr/bin/timeout 1s /bin/echo -e  "\nM999 P\"ERASE\"" > $PORT
        /bin/echo Waiting for board to settle
        /bin/sleep 5s
      flash()
        PORT=/dev/$(ls $1)
        /bin/echo @Flashing
        /bin/echo Board is: \(USB $(cat $1/../../idVendor):$(cat $1/../../idProduct)\)
        case `/usr/bin/timeout 5 $BOSSAC -i -p $PORT | grep Device | cut -d : -f2 ` in
        " ATSAM4S8")
          /bin/echo "Duet 2 Maestro (ATSAM4S8)"
      	bossa  $D2MF $D2MFURL $PORT && verifyversion $PORT 5s
        " ATSAM4E8")
          /bin/echo "Duet 2 Wifi/Ethernet (ATSAM4E8)"
      	bossa  $D2CF $D2CFURL $PORT && verifyversion $PORT 5s
        " ATSAME70x20")
          /bin/echo "Duet 3 6HC (ATSAME70x20)"
      	bossa  $D3 $D3URL $PORT && verifyversion $PORT 5s
          /bin/echo CPU not identified.
          /bin/echo lsusb:
          /usr/bin/lsusb
      esac
      bossa()
        FW=$1
        FWURL=$2
        PORT=$3
        #[ ! -s "$FW" ] &&
        echo Downloading $FWURL
        wget -q "$FWURL" -O $FW
        #flash with debug enabled, supress most of it
        [ -s "$FW" ] && /usr/bin/timeout 120 $BOSSAC -d -p $PORT -e -w -v -b $FW -R 2>&1  | tee bossa.log | grep -iv addr
        #delete log if successful
        grep "Verify successful" bossa.log &> /dev/null && rm -f bossa.log
      BOSSAC=~/BOSSA/bin/bossac
      if [ ! -f "$BOSSAC" ]; then
        [ ! -f /usr/bin/git ] && sudo apt install -y git
        git clone https://github.com/shumatech/BOSSA ~/BOSSA
        cd ~/BOSSA
        make bossac
      fi
      #test for Duets with working RRF vendor 1d50 product 60e?
      for i in $(find -L  /sys/bus/usb/devices/ -maxdepth 2 -name "tty*"); do
        grep -i "v1d50p60e[c-e]" $i/../modalias &>/dev/null && erase  $i
      done
      #test for SAM-BA vendor 03eb product 6124
        grep -i "v03ebp6124" $i/../modalias &>/dev/null &&  flash $i
      done
      Connecting a erased board shows udev is starting the script but it doesn't do much. I run the script as pi and it works fine as show by the logs
      Mar 16 05:40:12 duet3 kernel: [ 1980.232111] usb 1-1.1.2: USB disconnect, device number 16
      Mar 16 05:40:18 duet3 kernel: [ 1986.668315] usb 1-1.1.2: new full-speed USB device number 17 using dwc_otg
      Mar 16 05:40:19 duet3 kernel: [ 1986.800823] usb 1-1.1.2: New USB device found, idVendor=03eb, idProduct=6124, bcdDevice= 1.10
      Mar 16 05:40:19 duet3 kernel: [ 1986.800837] usb 1-1.1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Mar 16 05:40:19 duet3 kernel: [ 1986.801842] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
      Mar 16 05:40:19 duet3 root: /home/pi/duet_bossac.sh started
      Mar 16 05:40:27 duet3 pi: duet_bossac.sh started
      Mar 16 05:40:28 duet3 pi: duet_bossac.sh Duet 2 Maestro
      Mar 16 05:40:45 duet3 kernel: [ 2013.512104] usb 1-1.1.2: USB disconnect, device number 17
      Mar 16 05:40:46 duet3 kernel: [ 2013.808063] usb 1-1.1.2: new full-speed USB device number 18 using dwc_otg
      Mar 16 05:40:46 duet3 kernel: [ 2013.941183] usb 1-1.1.2: New USB device found, idVendor=1d50, idProduct=60ed, bcdDevice= 1.00
      Mar 16 05:40:46 duet3 kernel: [ 2013.941197] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      Mar 16 05:40:46 duet3 kernel: [ 2013.941207] usb 1-1.1.2: Product: Duet
      Mar 16 05:40:46 duet3 kernel: [ 2013.941216] usb 1-1.1.2: Manufacturer: Duet3D
      Mar 16 05:40:46 duet3 kernel: [ 2013.942212] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
      A little digging it seems udev runs in a sandbox that prevent access to networks and mounting file systems; while the script does download missing firmware files and tools it fails even if everything is in place.
      Maybe i just have to parse udevadm monitor or something to get around the sandbox, but if anyone has ideas I'm all ears!
      • A Former User
        could i ask @gtj0 and/or @wilriker to test the following on a non-raspberry / non-raspbian setup? (with any duet attached to usb)
        #!/bin/bash
          grep -i "v1d50p60e[c-e]" $i/../modalias &>/dev/null && echo /dev/$(ls $i)
        done
          grep -i "v03ebp6124" $i/../modalias &>/dev/null && echo /dev/$(ls $i)
        done
        wilriker 1 Reply Last reply Reply Quote 0
        • wilriker
          wilriker Moderator @Guest last edited by
          @bearer said in udev + bossa = failure to autorecover?:
          Of course I can
          $ uname -a
          Linux duet3-6HC 4.19.115-1-ARCH #1 SMP PREEMPT Fri Apr 24 14:53:41 UTC 2020 armv7l GNU/Linux
          $ ./the-bear-needs-test-helpers.bash
          /dev/ttyACM0
          Manuel
          My Tool Collection
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @wilriker last edited by A Former User
            Cool, seems to work. Thanks!
            (asuming /dev/ttyACM0 is a duet in one form or another:P)
            (goal is to avoid trying to flash a non duet that happens to occupy ttyACM0:)
            @wilriker said in udev + bossa = failure to autorecover?:
            • wilriker
              Yes, that's a Duet 3 permanently attached to RPi4 that runs DSF.
              I knew you'd like that. 😁 Also as I use fish I had to put it into a script. 😉
              BTW:
              $ lsusb
              Bus 001 Device 006: ID 1d50:60ec OpenMoko, Inc. (Duet 2 Wifi)
              Bus 001 Device 006: ID 1d50:60ed OpenMoko, Inc. (Duet 2 Maestro)
              Bus 001 Device 004: ID 1d50:60ee OpenMoko, Inc. (Duet 3)
              Did you hack your usb-ids or did you just add the values in parentheses yourself? I have submitted change requests to fix the names to usb-ids months ago but they do not accept them.
              Manuel
              My Tool Collection
              A Former User 2 Replies Last reply Reply Quote 0
              • A Former User
                ...sounds fishy!)
                just added them for my own pleasure, wasn't aware it made it to the forum.
                • wilriker
                  ...sounds fishy!)
                  You as a bear should like that, don't you? 😂
                  Manuel
                  My Tool Collection
                  • A Former User
                    usb-ids
                    huh poking around i find (but oddly enough not all fields for the bossa bootloader with the correct usb-id). oh well, enough to identify the board before querying bossa for the cpu type.
                    echo $(cat $1/../../manufacturer): $(cat $1/../../product) $(cat $1/../../version) \($( cat $1/../../idVendor):$( cat $1/../../idProduct)\)
                    Duet3D: Duet 2.00 (1d50:60ec)
                    edit:
                    seems there has been an update to usb-ids as well
                    pi@raspberrypi:~ $ lsusb
                    Bus 001 Device 031: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
                    Bus 001 Device 039: ID 1d50:60ec OpenMoko, Inc. Duet 3D Printer Controller
                    Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
                    Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
                    Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
                    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                    pi@raspberrypi:~ $
                    • gtj0
                      gtj0 last edited by
                      @bearer Here's my info from a Jetson Nano if you still need it...
                      duet3j /~# uname -a
                      Linux duet3j.f5.int 4.9.140-tegra-gtj8+ #5 SMP PREEMPT Sat Mar 14 08:58:08 MDT 2020 aarch64 aarch64 aarch64 GNU/Linux
                      duet3j /~# ./testudev.sh
                      /dev/ttyACM0
                      duet3j /~#
                      • A Former User
                        A Former User @gtj0 last edited by
                        @gtj0 awesome! just wanted to check if i could derive the tty device from usb ids across different combinations, so far so good.
                        • wilriker
                          Not really. 1d50:60ec has been in there for a very long time already. I added 1d50:60ed for Maestro and 1d50:60ee for Duet 3. Already back in October last year. But it still didn't make it into the release.
                          Manuel
                          My Tool Collection
                          • A Former User
                            ah, not often i have a wifi/ethernet connected, come to think of it I might initially have defered derived(?) the pid as 60ec based on maestro and duet 3. my bad.
