    Odd behavior after upgrade
    Firmware installation
    129
    • CthulhuLabs
      CthulhuLabs last edited by
      Hi all,
      Just upgraded my Duet from 2.02 to 2.05.1. I use a Capacitive Z-Probe for Z homing and probing. I am printing on a sheet of borosilicate glass that is fairly flat. Z is homed with the probe in the dead center of the bed.
      After upgrading I am getting really weird behavior when I probe the bed. I am getting this warning:
      Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
      4 points probed, min error 0.138, max error 0.225, mean 0.182, deviation 0.033
      Height map saved to file heightmap.csv
      And when I look at the height map it shows the 4 probe points floating above the Z=0 mark:
      4 Probe Points
      I normally probe with four points multiple times so I can adjust the four corners of my bed as close to 0 as possible. After that I apply glue stick and then probe again with thirty-six probe points to build the height map. This might be excessive, but this process has worked well for me. When I switch it to the 36 probe points things get even weirder though. My height map ends up looking like this:
      The above was also done with the glass completely clean with no glue stick on it. Prior to upgrading my height map never looked like this. I am not sure if I missed something in the upgrade notes about settings I need to change or something or if this is a bug. Below is my config.g:
      G90                                      ; Send absolute coordinates...
      M83                                      ; ...but relative extruder moves
      M550 P"CR-10S"                            ; Set machine name
      M551 P"Password:                       ; Set password
      M552 S1                                  ; Enable network
      M586 P0 S1                               ; Enable HTTP
      M586 P1 S0                               ; Disable FTP
      M586 P2 S0                               ; Disable Telnet
      M569 P0 S0                               ; Drive 0 goes forwards
      M569 P1 S0                               ; Drive 1 goes forwards
      M569 P2 S0                               ; Drive 2 goes forwards
      M569 P3 S0                               ; Drive 3 goes forwards
      M569 P4 S1
      M350 X16 Y16 Z16 E16 I1              ; Configure microstepping without interpolation
      M92 X80.00 Y80.00 Z1600.00 E409 ; Set steps per mm
      M566 X500.00 Y500.00 Z30.00 E120.00      ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E2400.00  ; Set maximum speeds (mm/min)
      M201 X900.00 Y900.00 Z200.00 E5000.00      ; Set accelerations (mm/s^2)
      M906 X800.00 Y1100.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                  ; Set idle timeout
      M208 X-6 Y-10 Z0 S1                         ; Set axis minima
      M208 X300 Y300 Z400 S0                   ; Set axis maxima
      M574 X1 Y1 Z0 S1                            ; Set active high endstops
      M574 Z1 S2                               ; Set endstops controlled by probe
      M558 P5 H5 F300 T6000 I1                 ; Set Z probe type to switch and the dive height + speeds
      G31 P500 X65 Y0 Z2.729                 ; Set Z probe trigger value, offset and trigger height
      M557 X65:235 Y65:235 S34                ; Define mesh grid
      ;M557 X65:235 Y65:235 S170
      M307 H0 B0 S1.00                         ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R4700              ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                             ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700              ; Set thermistor + ADC parameters for heater 1
      M143 H1 S286                            ; Set temperature limit for heater 1 to 280C
      M307 H0 A81.3 C675.5 D0.3 S1.00 V13.3 B0
      M307 H1 A260.1 C120.4 D5.6 S1.00 V13.6 B0
      M106 P0 I0 F500 H-1                 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                            ; Define tool 0
      G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
      G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
      M501
      G29 S1
      T0                                       ; Select first tool
      I started this config several years ago and based it off the online configuration tool at the time.
        Phaedrux Moderator @CthulhuLabs last edited by
        @CthulhuLabs said in Odd behavior after upgrade:
        ; Miscellaneous M501 G29 S1 T0 ; Select first tool {1}
        The warning about the Z Datum and the floating heightmap is because you are loading the heightmap at the end of config.g before the bed has been probed. Remove the G29 S1 from the end of config.g. The proper place for it is either at the end of your homeall if you want it to be active at all times, or in your slicer start gcode (or start.g in the /sys folder) if you only want it active for a print.
        The waves you see in the 36 point heightmap would indicate some backlash is present in your setup such that the probe is changing height as it changes directions on the X axis. Check your mount, belts, idlers, etc for any play.
        • CthulhuLabs
          So moving the G29 S1 did nothing, but fixing the backlash did. The eccentric spacer on my X carriage moved some how which is weird as I was printing on it just fine yesterday. I think the nylock nut needs replacing. So thank you. Glad it was something simple I overlooked.
            Would help to see your homeall and bed.g if you're using it. G29 S1 in the config.g may only be half of it.
            • CthulhuLabs
              homeall.g :
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v2 on Tue Nov 20 2018 10:49:57 GMT-0500 (Eastern Standard Time)
              G1 Z5 F6000 S2          ; lift Z relative to current position
              G1 S1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
              G1 S1 X-305             ; home X axis
              G1 S1 Y-305             ; home Y axis
              G1 X5 Y5 F6000          ; go back a few mm
              G1 S1 X-305 F360        ; move slowly to X axis endstop once more (second pass)
              G1 S1 Y-305             ; then move slowly to Y axis endstop
              G1 X100 Y150 F6000        ; go to first bed probe point and home Z
              G30                     ; home Z by probing the bed
              G29 S1
              ;G91                    ; relative positioning
              ;G1 S2 Z5 F100          ; lift Z relative to current position
              ;G90                    ; absolute positioning
              bed.g:
              ; bed.g
              ; generated by RepRapFirmware Configuration Tool v2 on Tue Nov 20 2018 10:49:56 GMT-0500 (Eastern Standard Time)
              G29  ; probe the bed and enable compensation
              • CthulhuLabs
                So I am still having problems with this. The 4 probe points are still floating above the Z=0 location, and when I print my first layers are not as squished down to the bed as they used to be.
                  Have you redone your z probe trigger height calibration recently?
                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                  • CthulhuLabs
                    Yes I did.
                    There seems to be error between the Z homing, and the bed probing. For instance I just configured the probing to do 9 points. The center point is the same spot that Z homes. I then homed Z and then immediately probed the bed. I then got the values from heightmap.csv. Without changing anything I homed Z again and probed the bed and got the heightmap.csv values again. Here are the results:
                    1st probe:
                    xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                    65.00,235.00,65.00,235.00,-1.00,85.00,85.00,3,3
                    0.000, -0.026, 0.049
                    0.011, 0.017, 0.026
                    0.032, 0.012, 0.066
                    2nd Probe:
                    -0.036, -0.057, 0.016
                    -0.024, -0.010, -0.008
                    0.000, -0.018, 0.035
                    What is interesting is the height map seems to have the same contour, but different offsets. Like the second height map is fairly evenly -0.03 mm lower than the first on all probe points. I am not really sure what exactly this means though.
                      Please can you test the repeatability of your z probe by running the macro outlined here: https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output/5?_=1585676517737
                      • CthulhuLabs
                        M292
                        G32 bed probe heights: 0.017 0.018 0.017 0.017 0.020 0.020 0.019 0.019 0.018 0.020, mean 0.018, deviation from mean 0.001
                        • CthulhuLabs
                          So I altered the Macro to this:
                          M291 P"Probe will be tested 10 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                          G28
                          M401
                          G30 P0 X150 Y150 Z-9999
                          G1 X100 Y150 F6000
                          G30 P1 X150 Y150 Z-9999
                          G1 X200 Y150 F6000
                          G30 P2 X150 Y150 Z-9999
                          G1 X150 Y100 F6000
                          G30 P3 X150 Y150 Z-9999
                          G1 X150 Y200 F6000
                          G30 P4 X150 Y150 Z-9999
                          G1 X200 Y200 F6000
                          G30 P5 X150 Y150 Z-9999
                          G1 X100 Y100 F6000
                          G30 P6 X150 Y150 Z-9999
                          G30 P7 X150 Y150 Z-9999
                          G30 P8 X150 Y150 Z-9999
                          G30 P9 X150 Y150 Z-9999 S-1
                          M402
                          To see if adding in movement operations would have a major influence on the results while still probing the same point. Here are the results:
                          G32 bed probe heights: 0.028 0.029 0.039 0.034 0.032 0.037 0.036 0.036 0.037 0.038, mean 0.035, deviation from mean 0.004
                            At least we know the probe itself is consistent, but there still appears to be some backlash in your mechanics.
                            • CthulhuLabs
                              I am just confused where this is coming from. I have checked X, Y, and Z and I cannot feel any slop.
                              • mladen001
                                mladen001 last edited by
                                hi @CthulhuLabs did you find resolution for this. I have exact same behavior when upgrading from 2.02 to 2.051
                                also no mechanical issue to be detected
                                thanks
