    Cannot connect Duet Wifi to new Wifi Router
    57
    3.4k
      droftarts administrators @GaRv3
      @GaRv3 Okay, fair enough. I've asked @dc42 to take a look.
      • Dougal1957undefined
        Dougal1957
        I had the exact same issue as this a couple of years ago eventually had to use a TP-LINK Travel router in AP Mode for the duet to connect to the issue was a Router that just didn't like the ESP at all (it was a nether one as well) once I replaced the router everything came back to normal.
        Doug
        • GaRv3undefined
          GaRv3
          @Dougal1957
          Did you replace the router with the sam model (so, was it defect) or did you pick another one?
          Dougal1957undefined 1 Reply Last reply Reply Quote 0
          • GaRv3undefined
            GaRv3
            So for now (until the wifi module arrives) I have connected an AP which I found in a closet to the second LAN port of my PC, created a wireless network and connected the Duet. Works just fine... as a temporary workaround.
            droftartsundefined GaRv3undefined 2 Replies Last reply Reply Quote 0
              @GaRv3 Glad you have a (temporary) solution!
                Dougal1957 @GaRv3
                @GaRv3 picked a different one I have just ordered a new connection with Vodafone UK so hope I don't have the same issue again (My current VF router is fine but the new line will come with the newer square ash router but in the UK I think they tend to use HuaWei stuff (Not that I am happy about but got no real choice))
                • GaRv3undefined
                  GaRv3
                  @dc42 Any suggestions?
                    @GaRv3 @dc42 said to me yesterday β€œyes, possible bug. It's on my list to do a new wifi server using the newer expressiv SDK, but it's not a quick job.”
                    • GaRv3undefined
                      GaRv3
                      Okay, thanks for the info!
                      Warstoneundefined 1 Reply Last reply Reply Quote 0
                      • Warstoneundefined
                        Warstone @GaRv3
                        @GaRv3 I got the same Problem but here is my option to deal with it part time πŸ˜‰
                        Hooked up my old D-Link Wifi router between the Vodafon router and my PC. It slows down my connection a bit, but the Duet is connecting without any problems to the D-Link instead of the Vodafon Router.
                        Works fine for me at the Moment πŸ˜‰
                        • GaRv3undefined
                          GaRv3 @GaRv3
                          @Warstone Yes, I did something similar. See this post.
                          But having the access point hooked up is just a workaround. Not a solution to the problem.
                          • i0n1zeDundefined
                            i0n1zeD
                            Hello i have a "same" prob.
                            I have updated my router and now I cannot use my DuetWiFi
                            My router settings only have WPA, WPA \ WPA2, WPA2 \ WPA3
                            But I suppose that I do not have TKIP support
                            And when I try to connect, nothing comes out 😞
                            Although in the clients on the router I see Duet attempts to connect
                              Phaedrux Moderator @i0n1zeD
                              @i0n1zeD sounds like a bad password attempt.
                              i0n1zeDundefined 1 Reply Last reply Reply Quote 0
                              • i0n1zeDundefined
                                i0n1zeD @Phaedrux
                                M587 S"Bazzz" P"qwe123qwe123"
                                ok<LF>
                                M552 S1
                                ok<LF>WiFi reported error: Timed out while trying to connect to Bazzz<LF>WiFi module is idle<LF>
                                  I suggest starting a new thread. Link to this one of you feel is relevant.
