    Waaaaaay too slow
    206
    • Super_Sonic_7036
      Super_Sonic_7036 last edited by
      Hello fellow forum members,
      My machine is working fine and well, but I have a minor issue. My homing speed is really, really slow. (my x and y axes are moving at about 0.5 mm/s). Overall, mesh bed probing is taking a little over an hour! Which part of my config file do I need to change to up the speed?
      Thank you for your consideration.
      • droftarts
        droftarts administrators @Super_Sonic_7036 last edited by
        @Super_Sonic_7036 Sharing your config.g and homeall.g files will allow us to help you. Also send M115 to the Duet, and post the response.
        • Super_Sonic_7036
          Got it. will do in just a bit
          • Super_Sonic_7036
            Here's my config file.
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Mar 09 2020 20:36:41 GMT-0500 (Central Daylight Time)
            M550 P"Printrbot Afterburner" ; set printer name
            M551 P"bruh" ; Machine password (used when you connect Duet Web Control or via FTP)
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X100.00 Y100.00 Z80.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X100.00 Y100.00 Z5.00 E250.00 ; set accelerations (mm/s^2)
            M906 X1500 Y1500 Z1500 E1500 I60 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X230 Y210 Z200 S0 ; set axis maxima
            M574 X2 Y1 S1 ; set active high endstops
            M574 Z1 S2 ; set endstops controlled by probe
            M558 P5 I1 E0 S0 H2.5 F20 T15 ; set Z probe type to inductive and normally open the dive height + speeds
            G31 P1000 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20 ; define mesh grid
            M140 H-1 ; disable heated bed
            M305 P1 B4725 C7.06e-8 ; set thermistor + ADC parameters for heater 1
            M143 H1 S280 ; set temperature limit for heater 0 to 280C
            M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P1 D0 H1 F0 S"Print Head" ; define tool 1
            G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets
            A Former User Phaedrux 3 Replies Last reply Reply Quote 0
            • A Former User
              A Former User @Super_Sonic_7036 last edited by A Former User
              @Super_Sonic_7036 said in Waaaaaay too slow:
              these are in mm/min not mm/s as maril or other have, could maybe explain your issue?
                Phaedrux Moderator @Super_Sonic_7036 last edited by
                Your F and T values are used for probing and travelling between points. They are set in mm/min, so you have them set to basically a standstill.
                Try F200 and T6000
                • Super_Sonic_7036
                  Thanks, I'll try that now.
                    Are you sure your Z steps per mm are 4000? That's the default used by the configurator, but chances are it's not right for your setup.
                    How is your Z axis setup?
                    Bearers comment goes for the other speed settings too. Your values are very conservative. You will have to do some testing, but they could all likely be increased by a factor of 10.
                    • Super_Sonic_7036
                      My Z-axis has been running fine, but I'll consider changing that if I see too it. Thanks for the concern.
                      • Super_Sonic_7036
                        And if anyone is wondering, I'm using a Printrbot Simple Pro bare-bones kit, so if you have any suggestions, feel free to tell me.
                        • Super_Sonic_7036
                          Update:
                          My mesh bed probing is moving at a much more desirable speed, thanks!
                          • Super_Sonic_7036
                            @Phaedrux
                            I took your suggestions into account as far as speed goes. I added a zero to the values that I thought could go faster, and my machine is now running at an even better pace. However, I had to reduce the acceleration and speed values of my extruder, as it was moving to fast, and it never properly gripped the filament. I'm still testing things as far as it goes, but so far, things are moving better.
