    stop.g using conditional G code
    • OwenD
      OwenD last edited by OwenD
      I'm slowly trying to use conditional G code is as many areas as possible.
      Currently I'm working on stop.g
      At present I only have one extruder, so in the example I know which heater is going to need to be checked to determine if I can do a retract, but that's poor coding from a portability stand point.
      I'm struggling to find how to check which tools and associated heaters are active so I can avoid hard coded references.
      so instead of
      if {state.currentTool!=-1} ; check if any tools are active
      	G91 ; relative positioning
      	if heat.heaters[1].state!="Off" && heat.heaters[1].current > heat.coldRetractTemperature
         	G1 E-2 F300 ; retract the filament a bit before lifting the nozzle to release some of the pressure
         	M291 P"Retracted 2mm" R"Retracting" S0 T5
      	else
         	M291 P{"Not retracted...  Heater off or below extrude temp  " ^ heat.heaters[1].current ^ " : " ^ heat.coldRetractTemperature ^ "."} R"Retract" S0 T5
         G4 S5 ; wait for popup
      I'd like to return either the currently active heater(s) in an array which can be passed either in a loop or a single statement.
      There doesn't seem to be a "maxHeaters" or similar in the object model that would allow me to do it in a loop.
      For interest here is the entire stop.g as it currently stands.
      There is some code that could be combined, but for testing purposes I have separated it even though I'm checking the same thing a couple of times.
      ; stop.g
      ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Jan 04 2020 09:46:45 GMT+1000 (Australian Eastern Standard Time)
      	if (heat.heaters[1].state!="off") && (heat.heaters[1].current > heat.coldRetractTemperature)
      	else
      else
      	M291 P"No active tool" R"Check tools" S0 T2
      if {!move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed} ; check if the machine is homed
      	M291 P"Insufficient axis homed.  Cannot retract or park" R"Parking" S0 T5
      else
      	G91 ; Relative positioning
      	if {(move.axes[2].machinePosition) < (move.axes[2].max - 10)} ; check if there's sufficient space to raise head
      		M291 P{"Raising head to...  " ^ move.axes[2].machinePosition+5}  R"Raising head" S0 T5
      		G1 Z5 F9000 ; move Z up a bit
      	else
      		M291 P{"Cannot raise head- insufficient space  " ^ move.axes[2].machinePosition ^ " : " ^ (move.axes[2].max - 10) ^ "."} R"Raising head" S0 T5
      		G4 S5 ; wait for popup to display
              G90 ; Absolute positioning
      	G1 X10 Y150 ; parks X head pushes bed out to front so you can pull part
      	M400 ; wait for current moves to finish
      	G10 S0 R0 ; Set active and standby temps to zero
      	T-1 P0 ; if any tools selected, deselect all
      else
      	T0 ; Select a tool
      	M116; wait for any temps to stabilise
      	G10 S0 R0 ; Set active and standby temps to zero to ensure nothing is on standby
      	T-1 ; deselect all tools
      M140 S0 ; heated bed heater off
      M106 P0 S0 ; part fan off
      M84 ; steppers off
      G90 ; absolute positioning
      M98 P"0:/macros/songs/itchyscratchy.g" ; play finish tune
      • OwenD
        @OwenD said in stop.g using conditional G code:
        {1}
        Not sure why these show in the code windows above. "{1}"
        They're not in my macro
          You can do something this (assuming either 0 or 1 heaters per tool):
          if state.currentTool >= 0
            if #tools[state.currentTool].heaters > 0 & heat.heaters[tools[state.currentTool].heaters[0]].current > heat.coldRetractTemperature
              G1 E-2 F300
          TypQxQ 1 Reply Last reply Reply Quote 0
          • OwenD
            Aaahhh!
            Missed that # operator.
            Frustrating coming from another language at times.
            Link for anyone else
            https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Unary_prefix_operators
            • TypQxQ
              TypQxQ @dc42 last edited by
              @dc42 said in stop.g using conditional G code:
                  G1 E-2 F300
              Just for information if anyone else pulls his/hers hair out wondering why it doesn't work.
              This will not work if the tool has 0 heaters because the whole second statemet is evaluated and an error is thrown.
              This works instead:
                 if heat.heaters[tools[state.currentTool].heaters[0]].current > heat.coldRetractTemperature
                   G1 E-2 F300
              Tested with RRF 3.4b6 on Duet3 6HC whithout SBC.
              dc42 1 Reply Last reply Reply Quote 1
                dc42 administrators @TypQxQ last edited by dc42
                @typqxq thanks for pointing this out. The original single condition gave me "Error: expected integer expression". This will be fixed in the next 3.4beta release.
